How to read single instance of recursive meetings in Outlook
  • Thread starter Thread starter Sindhura
Sindhura
I am creating an Add-in for Outlook in Vb.net . I need to read the
meetings between a given duration from a shared calendar. I am able to
read the non recursive meetings but when i try to read the recursive
meetings it always gives an item count of "2147483647".
I want the total count of meetings ( recursive + non recursive)
between the given time which should count only that instance of the
recursive meeting .
Here is the code sample which i am using:
Dim oApp As New Microsoft.Office.Interop.Outlook.Application
Dim oappt As Microsoft.Office.Interop.Outlook.AppointmentItem
Dim oNs As Microsoft.Office.Interop.Outlook.NameSpace
Dim oCalendar As Microsoft.Office.Interop.Outlook.MAPIFolder
Dim instance As Microsoft.Office.Interop.Outlook.Items
Dim oItems As Microsoft.Office.Interop.Outlook.Items
Dim recipient As Microsoft.Office.Interop.Outlook.Recipient
Dim oTask As Microsoft.Office.Interop.Outlook.TaskItem
Dim sSearch As String
Dim name1 As String
Dim date1 As String
oNs = oApp.GetNamespace("mapi")
oNs.Logon()
name1 = TextBox1.Text
date1 = DateTimePicker1.Text
recipient = oNs.CreateRecipient(name1)
oCalendar = oNs.GetSharedDefaultFolder(recipient,
Microsoft.Office.Interop.Outlook.OlDefaultFolders.olFolderCalendar)
oItems = oCalendar.Items
oItems.IncludeRecurrences = True
oItems.Sort("[Start]")
sSearch = "[START] >= '" & Format(date1) & " " & j & " ' and [START]
<= '" & Format(date1) & " " & k & " ' or [START] <'" &
Format(date1) & " " & j & " ' and [END] > '" & Format(date1) & " " &
j & " ' "
oItems = oItems.Restrict(sSearch)
If oItems.Count > 0 Then
TextBox3.Text = "Busy"
TextBox3.Text = "Free"
Can anyone please suggest me how to proceed.
That's a normal, known side effect of using IncludeRecurrences. The solution
is not to use Count. Instead, you can use a For Each ... Next loop to
process the items.
Sue Mosher
"Sindhura" <Sindhura> wrote in message
news:2AE715F9-9DE7-438C-BE93-B460B1D349D8@microsoft.com...
> Hi,
> recursive meeting .
> Dim name1 As String
> Dim date1 As String
> oNs.Logon()
> j & " ' "
> Else
> End If
> Thank you
S How to read single instance of recursive meetings in Outlook Outlook VBA and Custom Forms 1
Rupert Dragwater Mail won't show as read Using Outlook 2
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
D Can't read some emails - text size too small. Using Outlook 2
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
