Focus Change from Mailheader to body
  • Thread starter Thread starter Ria
Ria
Does anyone know how to catch the event from an inspector window (mail
message compose window) when the cursor is placed into the mailheader?
If I change the cursor from the mailheader to the body of the message,
Microsoft does disable the builtin formatting buttons, the are reactivated
when the cursor gets back into the body of the message.
I wish to use this same event disable/enable my custom buttons in the ribbon.
Anyone has an idea how to accomplish this?
You might use a timer, and check at intervall what's enabled. Here's a
sample for an API timer:
http://www.vboffice.net/en/developers/api-timer
Best regards
Michael Bauer
Am Sun, 21 Feb 2010 04:45:01 -0800 schrieb Ria:
ribbon.
A Focus on the userform Outlook VBA and Custom Forms 15
A Outlook 2007 message search results loses focus Using Outlook 7
S Outlook: Window loses focus when typing a new message Using Outlook 3
W frustrating trying to change email password Using Outlook 5
R Outlook 2021 change view Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
C Mass Change Selected Contact Photos Outlook VBA and Custom Forms 1
D Unable to change AppointmentItem.Start property Outlook VBA and Custom Forms 3
sjmo2 Change subject for new e-mails only. Outlook VBA and Custom Forms 2
Horsepower Contact phone numbers randomly change Using Outlook 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
whizzard Change FROM address based on TO or CC address Outlook VBA and Custom Forms 8
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
S Unable to change Message Class Outlook VBA and Custom Forms 0
C Outlook 365 Can you change the follow up colour? Using Outlook 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
Witzker HowTo Change message Class of contact form Outlook VBA and Custom Forms 0
R How to Change Margins In Google Docs...? Using Outlook 0
D Change senders title Using Outlook 1
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
B Change from Address Outlook VBA and Custom Forms 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
R Folder pane width change Using Outlook 90
