Outlook will not open
Luvmybaja
My Outlook 2010 will not open. It has been on my lap top for over a year and I can see the icon on my start menu (that shows my open items and available items), but when I click on it, it thinks about it, but does not open it. I tried to open it by going to All Programs/Microsoft Office but Outlook is not on the list any longer. Can you tell me what to do, please?
Thank you. Patsy
Which office suite do you have installed? If you type outlook.exe in the start menu's search field, does it come up - if you click it, does it run?
Hi Diane - No, it will not open. Interesting too. when I click on the Start / All Programs / Microsoft Office / there is not outlook to find.? It is like it uninstalled itself. The icon is still in my task bar, but all I get is the hourglass, no error, just the hourglass for a few moments then it stops and goes away and no Outlook. Thanks
you can also try opening Outlook in safe mode and check if you are able to view the mails. To do this,
1. Hold Windows key+ R key and type Outlook /safe->click ok. Now check if you are able to view the emails.
2. If Outlook safe works fine, try to disable add-in(s) from File->Options-> Add-in(s).
3. Click on go for COM-Add-Ins and clear the check box for all add-ins close and restart Outlook.
Hope this helps you.
Good Morning pctech33 (and Diane)
I wish I could say that it worked - but it didn't.
It's like it isn't even there. Like I said - I can go to Start / All Programs / Microsoft Office / and it isn't there. Why wouldn't it be there?
Any other ideas?
Thank you :)
K Outlook font corrupted in some point sizes, resets on close/open Using Outlook 2
Rupert Dragwater How to get Outlook 365 to open from websites Using Outlook 5
O Outlook on Android: after sharing / sending a news article, draft remains open. Why? Using Outlook 1
Witzker Open Contact missing in Outlook 2019 Using Outlook 2
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
C Can't Open Outlook 365 Using Outlook 0
M outlook won't open! Using Outlook 1
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
N open the hyperlink in Outlook directly instead of browser Using Outlook 1
A open Outlook with multiple windows. Using Outlook 0
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item Using Outlook 0
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
Diane Poremsky Outlook Links Won't Open In Windows 10 Using Outlook 1
L Outlook 2013 won't open MS Office attachments Using Outlook 1
Diane Poremsky Open Shared Mailboxes in Outlook on the Web Using Outlook 0
V Cannot start Outlook. Cannot open the Outlook window. Using Outlook 8
Z Outlook 2007, clicking email addresses fails to open Contact Using Outlook 0
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
J Outlook won't open. PST file busy. Using Outlook 3
M Cannot start MS Office Outlook Cannot open the Outlook window Using Outlook 2
Gareth Outlook Task Will not open. Using Outlook 5
D Outlook VBA to open Excel attachment and send recipient's email address to a workbook cell? Using Outlook 4
M Can't open same msg file more than once at the same time in Outlook 2010 Using Outlook 7
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
F Cannot open extracted .msg files from outlook Outlook VBA and Custom Forms 1
L Trying to open contacts pst. file in outlook 365 Using Outlook 3
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
L Outlook 2007 Open Folder From a Contact Using Outlook 22
B Add-in "always enabled" but Outlook 13 won't open Using Outlook 7
P open reminders missing after copying outlook pst file Using Outlook 2
L Outlook 2007 Macro Open Contact Folder Using Outlook 7
Lucas attachments in outlook don't open, when Icloud is connected Using Outlook 0
T Outlook 2010 Very Slow To Open Recently Using Outlook 9
