Read, unread, i'm losing clients!
kayte denham
Please help! 2007 Outlook. My incoming mail is un-bolding on one click or no click, showing that it has been read, when it has not been read.
How can I ensure that it only shows that it's been read when it has been opened? Please.
Forum Admin
Tools, Options, Other tab - Reading pane. I use only the option for Single key reading and Ctrl+Q to mark as read if i read in the reading pane and am finished with it. (I try not to mark messages read if I'm still working on them.)
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
G How to make outlook show as unread messages I read in my mobile ph or tablet Using Outlook 1
A How to Sort by Unread and then Read mail in Outlook 2007 Using Outlook 7
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
M TO field on Read Page not resolving Using Outlook 3
J From column changes when message is read Using Outlook 1
Z "Mark All as Read" in Outlook 2007 extremely slow Using Outlook 1
S Duplicate Read Receipt Using Outlook 4
