Outlook PST sync using Skydrive
WingsWest2
Outlook 2013 32 bit
I have a trial version of Office 365 and am using it hoping there is was a way to sync the Outlook PST between computers automatically. When using Apple mail your mail files are synced between your iPhone, iPad and iMac automatically without any user action. I had hoped Office 365 would have this feature as I have no Exchange Server. The question is can the PST be stored in Skydrive so each computer that opens Outlook can have identical information without moving/copying a PST between computers using some third party software? Apple does it why hasn't Microsoft done this as well? Am I missing something?
It works with apple mail because it's a IMAP account. It works the same in Outlook when you use imap accounts.
Outlook will do the same with Outlook.com/Hotmail calendar, contacts, and email.
Skydrive blocks pst files - apparently dropbox will sync pst files but you need to have outlook closed for the sync to work. Sugarsync tried but fills up the storage with a bunch of temp files in it's deleted storage - i don't know if it would have synced the pst as Outlook is usually open if the computer is running and I ran out of storage space.
Tip 1013: Can you use SkyDrive, DropBox or other cloud storage for pst files? - Outlook Tips
I use specific named PST (like Customer 1, Customer 2, project, various, travel, ...) to store and classify all my emails.
I don't keep email in subfolders of Outlook.pst linked to the account.
pst synchronization will be nice because once you transfer the email to the named pst, it is not available for the other device. Any suggestion ?
If the other device is a computer you can use skydive to copy the pst to another computer. If the pst doesn't change much this can work well. If it changes a lot, a sync utility such as sync2 or the similar utility from CodeTwo.com might work better.
Sent from my iPad using Tapatalk
Thank you for the answer. Yes, The other device is a computer. I understood from your previous answer on this page (Feb 2013) that Skydrive blocks PST. Has this changed ?
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
K Moved pst to new computer, now Gmail not coming into Outlook Using Outlook 7
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
HarvMan Outlook 365 PST Report Using Outlook 1
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
DariTrevino MIcrosoft Outlook PST file cannot repair Using Outlook 1
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
J Outlook 2016 - use of old PST file - will all emails be downloaded or only latest?? Using Outlook 1
P Moving Outlook.pst & archive1.pst Using Outlook 3
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
chai1949 pst file in outlook 2016 Using Outlook 3
Liz Schneider PST from Outlook 2013 is now IMAP folders in 2016 Using Outlook 10
Diane Poremsky Remove a password from an Outlook *.pst File Using Outlook 3
GregS Import from Outlook.com .ost to IMAP .pst? Using Outlook 3
O Missing guide "Move an Outlook Personal Folders .pst File" Using Outlook 4
R Outlook PST not opening Using Outlook 1
U .pst file error at opening outlook Using Outlook 1
Diane Poremsky How to repair a damaged Outlook Personal Folders file (pst) Using Outlook 0
S Portable MS Outlook or similar using PST Using Outlook 0
Z Importing PST files from Outlook 07 to Outlook mac Preview Using Outlook 1
B No permission to access Outlook.pst file Using Outlook 1
S How to restore corrupted PST file over 2GB in Outlook 2007 Using Outlook 2
G pst file restore Outlook 2013 from HTC One M9 Using Outlook 1
R can I transfer outlook data from old pc by using .ost file instead of the .pst Using Outlook 5
L what is safe size for pst of Outlook 2013 via Office 365 exchange? Using Outlook 1
