Line/Body width one or two characters
Billsv1
I use outlook 2010.
SOME of my email recipients complain that the emails I send them are only one or two characters wide.
This ends up with the entire email strung out like this:
h
e
l
l
o
Is it caused by my email program or his?
How can we fix it?
S [O2007] -> How to search for a string in the body and get the line number? Outlook VBA and Custom Forms 1
G How to export a particular line in the body of the mail to excel? Outlook VBA and Custom Forms 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
T In-line reply style in Outlook II Outlook VBA and Custom Forms 1
F Auto changing email subject line in bulk Using Outlook 2
R Outlook Working off line Using Outlook 0
D Prompt to prefix subject line whenever sending an email Outlook VBA and Custom Forms 3
R 550 maximum allowed line length is 998 octets, got 1012 Using Outlook 7
2 How to get rid of the "Emailing:" prefix in the subject line Using Outlook 1
O Carriage Return - Line Feeds - exporting Calendar events Using Outlook 0
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
O Double line spacing - solved with minor drawback Using Outlook 0
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
C Change Subject Line in Selected Emails Outlook VBA and Custom Forms 1
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
C Outlook - cannot save subject line changes Using Outlook 2
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
J Marco in search of text in subject line Using Outlook 8
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
Harald Olsen Automated insertion of address in address line Using Outlook 1
P Can't see full text in From and Subject line Using Outlook 1
D dropdown list in new email in subject line Using Outlook 4
T In-line reply style in Outlook Outlook VBA and Custom Forms 20
N Rename Subject Line with Email Content Outlook VBA and Custom Forms 3
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
I Make a macro in line rather than pop out Outlook VBA and Custom Forms 0
