Mail problem
Eddie
Up today I use to open my work mail on yahoo.com
I created an outlook account on my PC and linked with mywork mail
myname@domain.com
The synchronization lasted some hours, later my mailsstarted deleting from my account. first they were sent to trash than delete.
What's happening?
So you created an email account in Outlook for your work account and it deleted mail from the server? did you set iut up as POP3?
yes I created my account on outlook 2007 using pop for my work account.
I can also open this mail account in yahoo.com but I needed in my PC, so I created an Outlook account.
Before completion of the sync I opened my mail on my cellphone and saw that a lot of recent mails on Inbox were missing.
At a time the trash box was filled with mails and a few seconds later they were deleted either from trash box.
Any idea?
Go to Tools, Account Settings. Double click on the work account, click More Settings. Switch ot the Advanced tab and set Outlook to leave mail on the server. Screenshots: leave mail on server
If the work account supports IMAP, that is usually a better option. If you need the mail on the server and have imap, you could create the IMAP account in outlook and move mail from the pop3 data file to the imap folder - after disabling send and receive on the pop account.
T Problem With Mail Setup IN Outlook 2013 Using Outlook 2
D Problem with MS mail and outlook 2007 OS Windows 8 Using Outlook 1
S Problem syncing mail from a POP3 account in Outlook 2013 to iphone 5 Using Outlook 1
B Problem with new imap mail account with delete not working as I would like Using Outlook 2
R problem with incomming e-mail I am unable to print full e-mail letter Using Outlook 1
M Problem/Glitch with unread mail and going back to inbox --- missing emails Using Outlook 1
A E-mail accounts problem !!! Using Outlook 7
E Outlook invitation request mail sending twice problem Using Outlook 1
N Automating Outlook 2007 problem with sending mail Outlook VBA and Custom Forms 1
P UserProperty of mail object problem while dealing with custom fold Outlook VBA and Custom Forms 2
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
Rupert Dragwater Mail won't show as read Using Outlook 2
O Junk E-mail Options disabled(?) Using Outlook 3
E Replying to a plain text e-mail with HTML Using Outlook 2
P Limited Support for 3rd Party Mail in new Outlook? Using Outlook 1
T Exchange Server - Mail Delay Stamping Exchange Server Administration 0
L Error when exporting Sent Mail to Excel Outlook VBA and Custom Forms 6
P What is your strategy for dealing with SPAM and Junk Mail? Using Outlook 1
A manual rule sends mail to wrong folder Using Outlook 5
Cathy Rhone Mail merge error message Using Outlook 1
