Outlook(hotmail)Yahoo problem
kgolfs
Outlook 2013 64 bit
Just started using the new Outlook & my hotmail address. Tested it sending an email to my Yahoo acc't on PC and Yahoo is not receiving it. It goes to a local co's email-- gvtc.com, but not Yahoo. What's the problem? My niece's business address is on Yahoo and I need to communicate with her. K.
it's a non-delivery report. Do the messages arrive if you log in to outlook.com to send them?
What antivirus / security software do you use? some software includes a mail filter and could be blocking it.
When I use hotmail it uses outlook. I have not blocked it at yahoo. I use Avast. I've tried the Yahoo forums w/ no success.
When you use the hotmail website, it uses outlook.com, not Outlook 2013. The website uses a different SMTP server and bypasses potential problems between the server & Outlook 2013.
Disable Avast and send a test message - avast is one of the programs that filters mail.
I finally fixed the problem. Two things in Yahoo-- first- edit acc't under 'Settings'-Add Extra Email to 'receive' emails from Hotmail and second, under My Account, Edit Acc't- add it as a tertiary address for Yahoo to contact me that I 'changed' something in my personal acc't. That fixed it. But, none of these suggestions were found anywhere when I Googled the problem or under Outlook Forum or Yahoo Forum. I was just very persistent.
Thanx for your help. KDR
F Outlook 2010 and Hotmail Using Outlook 1
J Hotmail drafts started on desktop disappear, but show in web version of Outlook Using Outlook 4
Z Hotmail account deleted from outlook and issue with account not exist Using Outlook 0
J 'Name on the security certificate is invalid or...' - Outlook on desktop talking to hotmail.com account Using Outlook.com accounts in Outlook 6
F My hotmail calendar is not syncing with my outlook but my email is Using Outlook 3
J Accessing Hotmail accounts with Outlook 2016 Using Outlook 3
B Headache with Hotmail and Outlook since migration Exchange Server Administration 10
V Hotmail account on Outlook 2010 Using Outlook 2
Ascar_CT MS Outlook 2010 with Hotmail connector went spam control nuts Using Outlook.com accounts in Outlook 1
S Can't login to Hotmail account to use Outlook Using Outlook 2
B Outlook.com (formerly hotmail.com) and sending meeting invitations Using Outlook 1
R Cannot Synchronize Outlook To Windows Live Hotmail Account Using Outlook.com accounts in Outlook 2
P Outlook - Hotmail/Outlook.com issue Using Outlook 3
M Microsoft Outlook Hotmail Connector Error: The text exceeds the limit of 1024 Using Outlook.com accounts in Outlook 1
V Outlook 2013 and Hotmail Using Outlook.com accounts in Outlook 1
A Missing Folders From Hotmail Account which are in my PC Outlook 2013 PST file Using Outlook.com accounts in Outlook 1
Z Making Outlook Default folders to local/personal instead of Hotmail Using Outlook 8
A Disable hotmail from Outlook email account Using Outlook 1
A Need May 2011 14.2 Outlook Hotmail Connector. Using Outlook.com accounts in Outlook 1
R Outlook Connector will not download ALL messages from hotmail accounts Using Outlook.com accounts in Outlook 4
S Outlook doesn't download all hotmail emails on Vista Using Outlook 2
H Hotmail set not to delete from other accounts, but did. Settings in Outlook? Using Outlook.com accounts in Outlook 0
V What is wrong with Outlook Connector - it still errors out on an EMPTY Hotmail Using Outlook.com accounts in Outlook 3
B Outlook 2003 can't sign in to my Hotmail account Using Outlook.com accounts in Outlook 1
L remove a hotmail account from Outlook 2007 running on Vista home premium Using Outlook.com accounts in Outlook 1
A Messages sent from Outlook 2010 display incorrect 'sent to' name in Hotmail Using Outlook.com accounts in Outlook 4
P [SOLVED] Outlook-Hotmail Birthday Calendar changed by one day Using Outlook.com accounts in Outlook 8
B Outlook contacts with Hotmail. - Error >>>The text exceeds the limit of 1024 characters. Type a shor Using Outlook 4
C outlook hotmail connector update killed my outlook - please help!! Using Outlook.com accounts in Outlook 3
R Outlook reports Error 4203 when Hotmail Connector syncs Outlook VBA and Custom Forms 1
M Missing/Blank Hotmail Emails from Outlook but appear in hotmail BCM (Business Contact Manager) 1
P Setting Hotmail Junk Mail Settings from Outlook Doesn't Work Using Outlook.com accounts in Outlook 1
H Outlook 2007 Dropped Hotmail Account Using Outlook 4
W Why use Outlook Connecter now that Hotmail supports POP3 Using Outlook.com accounts in Outlook 1
N Distribution list does not sync from Outlook to hotmail Using Outlook.com accounts in Outlook 1
D Hotmail Folders in Outlook Using Outlook.com accounts in Outlook 7
J How do I import MSN Hotmail Calendar into Microsoft Outlook? Using Outlook.com accounts in Outlook 1
W Syncing Hotmail Calendar to Outlook 2003 (SP3) Using Outlook.com accounts in Outlook 2
Y messages deleted in Outlook 2007 not uploading changes to hotmail Using Outlook.com accounts in Outlook 1
Z How to move Hotmail folders to Outlook 2007? Using Outlook 6
S Connect Outlook Calendar with Hotmail Calendar Using Outlook.com accounts in Outlook 10
G Data Left Behind when Migrating To Outlook from Thunderbird - Insights on the Issue Using Outlook 0
V Outlook spam filter misbehaving Using Outlook 6
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
