Message Save add ins do not work with EAS
David KS
I have about 60 individual folders in Outlook. I need an add in to help file outgoing messages. I have tried several and they all worked quite well until I changed the email account to EAS to sync with my laptop and my windows phone.
Now all outgoing messages end up in Sent Items even though I may have specified an individual folder.
It seems that EAS is overriding the add in.
Does anyone know an add in that can handle EAS?
I suppose an alternative would be to use IMAP for syncing messages and EAS just to sync contacts and calendar but that's a complication I would like to avoid.
David
The issue is that EAS doesn't support moving sent items like that. I haven't tested a macro to see if that would work. Are you filing the messages in different folders or in one folder, just not the sent folder?
I want to file the messages into individual different folder - about 60 of them - one for each of my clients. Under POP or IMAP the add-in or routine asks you to confirm or suggest the destination folder and files the message there. Under EAS it ignores the request and dumps the message in your default Sent Items folder. I can them move the messages manually to the correct folder.
Thanks for your trouble
David
I will test a macro - I think because manual works, that a macro will but I've been wrong before. :)
Does the folder match their display name? That is usually the easiest way to automatically match mail to a folder. (We'll worry about that once we see if the macro can do it.)
Scratch that - it thinks about it forever then fails. You'll have to move them yourself. It's a limitation of EAS...
If you own your own domain, Office365 hosted Exchange is a good option. Not free, but definitely business-quality. If you use multiple computers, outlook is identical on all, it syncs great with all devices.
I rather feared as much.
Thanks so much for your trouble.
David
Diane Poremsky Save Selected Email Message as .msg File Using Outlook 11
Diane Poremsky Choosing the Folder to Save a Sent Message In Using Outlook 0
L Save message from outlook to desktop in 2013 outlook Outlook VBA and Custom Forms 1
L Save Mail Message to new folder created automatically Outlook VBA and Custom Forms 1
M Save selected email message as .msg file (with user to choose folder location) Outlook VBA and Custom Forms 14
R VB code to bulk save attachments deletes message Using Outlook 1
S how to disable security message in save attachments macro "A programis trying to access e-mail addre Outlook VBA and Custom Forms 5
P SPAM message about Comcast email migration to Yahoo Using Outlook 1
P deleted message keeps reappearing10-20-more times Using Outlook 3
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
Terry Sullivan Unwanted Duplicate E-Mails -- One with My Message and the Other Blank Using Outlook 0
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
E "The operation cannot be performed because the message has been changed" Using Outlook 4
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
D Outlook 365 Outlook Message "Cannot be sent because the message has changed" Using Outlook 0
B Please remind me how I added this message button Outlook VBA and Custom Forms 0
E PgUp and PgDn don't work for displayed message content (but do for web pages) Using Outlook 4
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
F Outlook 2019 Forwarding Message and Keeping Unread Status Outlook VBA and Custom Forms 0
A rule name into message - how? Outlook VBA and Custom Forms 5
A Links in email getting error message about group policy Using Outlook 4
Commodore Unable to move message Using Outlook 3
Y Disable Microsoft Outlook Test Message Using Outlook 4
S Unable to change Message Class Outlook VBA and Custom Forms 0
S Changing Message Class Outlook VBA and Custom Forms 4
Cathy Rhone Mail merge error message Using Outlook 1
