Save E mail using different path.
Dear Diane
Thanks for your help. I will try this code as soon as possible. For now mine is obviously working and i already start to work on another one. But, i'm curious to try your code, specialy the "Case" part.
Anyway, thanks for helping. I'll keep you in touch with testing your lines.
Fred
Yeah :) It works great. Every time a mail which is under a rule, incomes, mail is tidied in the correct sub-folder and saved by the script executed by rule :p
But now i have another challenge...
This deals with attached file. I'm specialy interrested by two type of mails :
- Nornofolio Details
- Plassit Rice
I'm adding two rules in Outlook because besides saving mail on network, i need to extract attached file too.
'----------------------Règle 8-------------------------------------------------------------------------------------------------------
Sub rule_ExtractCP(Mail As Outlook.MailItem)
  FundType = "Tlassic Rice"
  Call ExtractCP(Mail, "H:\XXX\99. DWH\EXTRACTION\Tlassic Rice\", FundType)
with
Sub ExtractCP(MyMail As Outlook.MailItem, repertoire, FundType)
and
Sub ExtractPD(MyMail As Outlook.MailItem, repertoire, FundType)
with
'----------------------Règle 9-------------------------------------------------------------------------------------------------------
Sub rule_ExtractPD(Mail As Outlook.MailItem)
  FundType = "Portfolio Details"
  Call ExtractCP(Mail, "H:\XXX\99. DWH\EXTRACTION\Nornolio Details\", FundType)
I already have a macro which is working perfectly. Aim of this macro is too seek into "Extraction" Outlook sub-folder for mails. For each of mails found, Macro opens attached file, read and copy A2 cell information and paste it in the Excel file of Macro. At the end, macro use pasted cell to create name of file on network.
I did it because i need to name my files with information took into attached file...
This is the code :
Macro is in a module of an Excel file named "Extraction - Browser.xlsm"
Sub RetrieveMailFiles_Click()
Dim MonOutlook As Outlook.Application
Dim ns As Namespace
Dim Inbox As MAPIFolder
Dim Item As Object
Dim Atmt As Attachment
Dim FileName As String
Dim Mypath As String
Dim i As Integer
Dim dtDate As Date
Dim sDate As String
Dim sName2 As String
Dim sName3 As String
Dim Inbox2 As MAPIFolder
Dim Inbox3 As MAPIFolder
Dim Td As Date
Dim Rd As Date
Dim Nd As String
Dim awb As Workbook
Dim aws As Worksheet
Set ns = GetNamespace("MAPI")
Set InboxFold = ns.GetFolderFromID("00000000CA5063795BBABA4E85B7BB93FA4923A901001D2C09AE1B48E742934DA9D063E6543B000000E6E19D0000")
Set awb = ActiveWorkbook
Set aws = awb.ActiveSheet
Dim d As String
Application.ScreenUpdating = False
    For Each Item In InboxFold.Items
        For Each Atmt In Item.Attachments
'-----------------------------------------------------/ AAA /----------------------------------------
        If Item.UnRead = False And Right(Atmt.FileName, 3) = "xls" And Item.Body Like "*AAA*" Then
    'Creation of a Temp file "datefile" which is a pasting of attached file
            FileName = "H:\XXX\99. DWH\EXTRACTION\datefile.xls"
            Atmt.SaveAsFile FileName
            Workbooks.Open FileName
    'Copy of "A2" cell whichi is.....
            Range("A2").Select
            Selection.Copy
    'Pasting data from A2 to B2 in "Extraction - Browser.xlsm"
            Windows("Extraction - Browser.xlsm").Activate
            Range("B2").Select
            ActiveSheet.Paste
            Application.CutCopyMode = False
    'Opening of "datefile"
            FileName = "H:\BSI ManCo\Control Function\99. DWH\EXTRACTION\datefile.xls"
    'Copy of E2
            Range("E2").Select
            Selection.Copy
    'Pasting of E2 in B3 in "Extraction - Browser.xlsm"
            Range("B3").Select
            ActiveSheet.Paste
    'Closing of "datefile..xls"
            Workbooks("datefile.xls").Close
            Kill FileName
    'Final File Creation
            ActiveWorkbook.Save
                sDate = aws.Range("D2").Value
                sName2 = aws.Range("D3").Value
                sName3 = aws.Range("B4").Value
            FileName = "H:\99. DWH\EXTRACTION\" & sDate & " - " & sName2 & " - " & sName3 & ".xls"
            Item.UnRead = False
'-----------------------------------------------------------------/ BBB /----------------------------------------
                    ElseIf Item.UnRead = False And Right(Atmt.FileName, 3) = "xls" And Item.Body Like "*
'-----------------------------------------------------------------/ CCC/-----------------------------------------
'-----------------------------------------------------------------/ DDD/----------------------------------------
    'Next Attachment in same mail
       Next Atmt
    'Next Email
    Next Item
'Kill FileName
If InboxFold.Items.Restrict("[UnRead] = True").Count = 0 Then
        MsgBox "NO Unread Email In Multichallenge Globes Inbox"
Well...both macro are perfectly working but i have to find a way to adapt second one in Outlook. For now the part
does not suit with because i'm not extracting mails in Outlook but mails in Windows browser !
so you want to put H:\XXX\99. DWH\EXTRACTION\Nornolio Details\saved-filename.ext in the cell?
Assign the path and filename to a global variable
or if i misunderstand what you need to do and you just need to convert this:
to the default inbox, use
Set InboxFold =Ns.GetDefaultFolder(olFolderInbox)
Not exactly Diane.
My incoming mails (the .msg files) are saved in a network drive (to H:\XXX\99. DWH\Incoming Mails) thanks to an Outlook rule which runs also a script. Ok
Now i would like to add a rule (and a script) in order to extract attached file.
I already have a macro to do the extraction and it works fine but this macro is made to seek mails in an Outlook folder and i would like to seek into a network drive (H:\XXX\99. DWH\Incoming Mails)
L Save Mail Message to new folder created automatically Outlook VBA and Custom Forms 1
P How to save sent mail and forward it the next day Exchange Server Administration 3
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
F CAN'T SAVE OUTLOOK 2010 E-MAIL TEMPLATE (.oft) Using Outlook 1
M how to save incoming mail in TRUE csv format Outlook VBA and Custom Forms 1
B Save e-mail to .msg file Outlook VBA and Custom Forms 4
S how to disable security message in save attachments macro "A programis trying to access e-mail addre Outlook VBA and Custom Forms 5
R Unable to save complete email to File Explorer Using Outlook 2
J Save Dialog Outlook VBA and Custom Forms 2
M Save as Adobe PDF misses inline graphics Using Outlook 0
Sandgroper48 Save vbaProject Outlook VBA and Custom Forms 2
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
S automate save the .xlxs file to share Network Using Outlook 1
