Template oft that contains VBScript Is not running
JorgeDario
Dear:
I have a template that is stored in the address "c:/mytemplates/myoft.oft"
The file "myoft.oft", has a vbscript script incorporated: Function Item_Send()
The template opens with the macro: Application.CreateItemFromTemplate(c:/mytemplates/myoft.oft) but does not run the script.
How to make to run the script of the template that is created after open with CreateItemFromTemplate?
You didn't get a warning that the form needed published? Forms with Scripts need to be published, Forms with controls need to be opened using the Choose Forms explorer (New Items > Other Items > Choose Form the first time, then New Items > Custom Forms.
to publish the form, you need to show the Developer ribbon then open the template and publish.
Publishing Custom Forms in Outlook
F CAN'T SAVE OUTLOOK 2010 E-MAIL TEMPLATE (.oft) Using Outlook 1
N How to automatically update all fields in an Outlook message template (OFT)? Using Outlook 9
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
T Outlook Template - textbox visible based on combobox selection Using Outlook 1
L Outlook saved template function too limited Using Outlook 2
K Outlook template Using Outlook 1
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
B Switch template with account Outlook VBA and Custom Forms 3
Diane Poremsky Using the Outlook Calendar Template Using Outlook 0
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
A VBA to create meeting from template from a time slot selected in someone's calendar Outlook VBA and Custom Forms 5
Q Editing an outlook. Template file (Otk) Using Outlook 1
P Calendar template Using Outlook 2
M Update field codes when opening Outlook Template Outlook VBA and Custom Forms 2
J Outlook template with environ varaibles Outlook VBA and Custom Forms 0
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
T My Outlook Calendar Template Using Outlook 1
S Ask user to input email template through VBA Outlook VBA and Custom Forms 1
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
B Outlook to Word Template error Using Outlook 4
I how to create appointment using saved template onto public folder shared calendar Using Outlook 3
S Modify account template? BCM (Business Contact Manager) 0
J Adding original email text to outlook message template Outlook VBA and Custom Forms 2
M How to create a document or email template for Opportunities BCM (Business Contact Manager) 0
S Workgroup template file location? Using Outlook 2
D outlook 2010 template accessable to others at work... Using Outlook 1
W Change Template Recipient Automatically - Outlook 2007 Using Outlook 5
W Template to produce calendars with wrapped text & user-defined fields? Using Outlook 1
C Monday Start Monthly Template Using Outlook 0
R How to use an outlook template globally in an organization Using Outlook 1
D Selection of Send-From Account with Template VBA Shortcut Using Outlook 0
L Contact Template Using Outlook 18
R How to design custom template under message/mail form ! Using Outlook 0
