"Post" icon on some contacts
Wade Campbell
Outlook 2016 64 bit
I have also noticed that a few of my contact items have a "Post" icon instead of the normal "Contact" icon. Other forums suggest that this is due to a different or incorrect 'message class'; however, I have checked the message class and it is the same as all the contact items that have the "Contact" icon.
I do not have journaling turned on.
Why is this, and is it an indication of a problem that requires fixing?
Are you using a custom form? It's normal to have the post icon when you use a custom form (it's the default icon for all custom forms and many people don't bother to change it.)
If you use a custom form, then it's definitely nothing that needs fixed. If you aren't using a custom form and everything else is working ok, i wouldn't worry about it.
F Outlook 365 Can I attach 2 files to to post? Using Outlook 1
O How to delete a forum post? Using Outlook 4
Fozzie Bear Cannot post "Sneaky URL"!! Using Outlook.com accounts in Outlook 2
PMR0001 Mydomain Outlook.com and Exchange post EAS Using Outlook 1
wallisellener Unable to reply/post/create new thread using Chrome BCM (Business Contact Manager) 5
H Where to post code in Outlook Outlook VBA and Custom Forms 1
M Custom form on one page to post contents on second page Outlook VBA and Custom Forms 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
B Excel 2010 vba to post appts to different outlook calendars at the same time Using Outlook 6
A Post Form Follow Up Flag Using Outlook 4
A POST customized as a form Using Outlook 2
C How do I share/post my calendar to public folders Exchange Server Administration 3
T OWA and post dating Exchange Server Administration 1
I Post outlook connector installation syndrome - Standby gone Using Outlook.com accounts in Outlook 3
B Post form into share calendar Outlook VBA and Custom Forms 1
R Hi, ken, GetState problem again, come in this post please? Outlook VBA and Custom Forms 4
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 7
F Outlook 2021 Inbox delete icon missing Using Outlook 5
S Paperclip icon shows without attachment in email under Sent folder Using Outlook 0
J Text icon in Quick Access toolbar ? Using Outlook 2
M New icon? Using Outlook 3
W Get a "New Note" icon onto the QAT Using Outlook 3
Commodore Attachment icon when there is no attachment Using Outlook 3
J Control Panel Mail (settings) icon missing Using Outlook 2
G Outlook 2016: reply icon not showing when replied from mobile Using Outlook 3
E What does mean this icon at the picture attached? Using Outlook 2
P Delete Icon Using Outlook 2
Witzker Change icon for custom views Using Outlook 1
D Email Icon Column Using Outlook 2
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
A Change Outlook Taskbar Icon Using Outlook 0
P IM and Phone icon is Grayed out in Outlook 2013 - Using Lync 2013 Using Outlook 4
wisedave Missing icon that show message was forwarded, etc Using Outlook 1
F Custom contact form icon issue Using Outlook 1
M Floating Delete Icon in mail list Using Outlook 1
V Reply Arrow Icon appears when both Replying or Forwarding Using Outlook 3
T Add 'Move to folder' icon to custom form Using Outlook 1
J phone icon greyed out in outlook 2013 Using Outlook 1
H how to change the Folder icon in Contact Using Outlook 7
M Remove sharing icon from outlook contacts Using Outlook 6
A No profiles created problem in outlook after clicking outlook icon Using Outlook 0
D How do I get a new mail icon into my quick launch bar? Using Outlook 3
D How do I run a rule by using a toolbar icon? Outlook VBA and Custom Forms 4
M How to resize the instant search pane on click on the icon to expand/ Outlook VBA and Custom Forms 1
S show icon while toolbar button is disabled. Outlook VBA and Custom Forms 1
