Outlook 2019 Not Using Auto Compete After Deletion of 365
terri610
I had been using Outlook 365 but now only using Outlook 2019. It no longer is remembering names and auto complete is checked. Even if I send someone an email and insert the address manually, it still does not remember it the next time.
This is just so time consuming to look up addresses and there has to be an answer!
Thank you in advance for any suggestions~
I feel your pain as I got the same thing - I migrated from O365 to SMTP FastMail. It works great but the auto-complete appears lost :(
The best sollution seems to be to type a few letters of the email recipeinet in the "To" field and then lcik the "@Check Names" button. This will pull a meny of potential email recipeients from your Outlook contatcs database.
H Force Outlook 2019 with GMail 2-Step to Require Login? Using Outlook 0
D Outlook 2019 is no longer asking for password ... Using Outlook 5
A Outlook 2019 folder counter Using Outlook 0
K Changing the Deleted Items location in Outlook 2019 Using Outlook 2
R Outlook 2019 accesses POP3 but says its offline (because of IMAP servers?) Using Outlook 0
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
H Outlook 2019 intermittent search results Using Outlook 0
K Outlook 2019 Randomly Disconnecting from Gmail Servers Using Outlook 8
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
Witzker Outlook 2019 is cutting Picture Extension *.pn_ Using Outlook 3
Albert McCann Outlook (and Office) 2019 Logging Using Outlook 2
Witzker Open Contact missing in Outlook 2019 Using Outlook 2
C All Gmails don't show in Outlook 2019 Using Outlook 2
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
J How do I disable advertising in Outlook 2019? Using Outlook 15
R Outlook 2019 Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
W Outlook 2019, Outlook Proplus v1808/1809 Unexpected Calendar Cache Using Outlook 4
G Data Left Behind when Migrating To Outlook from Thunderbird - Insights on the Issue Using Outlook 0
V Outlook spam filter misbehaving Using Outlook 5
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
W New Outlook PEOPLE blank Using Outlook 6
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 3
