Populate form data into message body
ckcango
Outlook 365 32 bit
Help!! I am VERY new at this outlook form thing. I have created a phone message form (message format) with all the info I need (it has taken me 3 days to fumble through it with trial/error and google). I also figured out how to automatically put some of the data into the subject line of the email automatically when I hit send. I use the message body section for any "notes" about the phone call the receptionist may need to pass on. All works great! BUTTTT I cant for the life of me figure out how to populate the data into the message body at all, let along adding it and not loosing the "notes". I found this thread and it seems like it may fit, but I have no idea where all this script goes/how to use it or if its even the correct thing. Some guidance from someone way smarter than me about this stuff would be super helpful and appreciated!!
prior thread
S Populate textbox values from one form to another form. Using Outlook 0
R Populate Form with appointments from Calendar Outlook VBA and Custom Forms 1
J populate word template from Outlook custom form Outlook VBA and Custom Forms 2
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
A Populate Listbox from Txt File Outlook VBA and Custom Forms 0
A Populate Textbox from Txt File Outlook VBA and Custom Forms 1
Diane Poremsky Outlook VBA: Use a Text File to Populate a ListBox Using Outlook 0
T populate calendar with appointments and send reminders Using Outlook 1
A Populate Excel from Outlook Userform Outlook VBA and Custom Forms 3
J Live Meeting Location populate from body Outlook VBA and Custom Forms 4
A How can I populate a dropdown list? BCM (Business Contact Manager) 4
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
A Cannot populate IMAP folders Using Outlook 1
S Pre populate subject + body + attachment to already open email in outlook 2007 Using Outlook 2
B Auto Populate From Field Using Outlook 3
G Populate an Outlook 2007 template with spreadsheet data. Outlook VBA and Custom Forms 1
G Populate BCC field with all Contacts within a Contact Folder Outlook VBA and Custom Forms 4
M Create new Contacts folder and populate it from Access Outlook VBA and Custom Forms 1
A Macro - Open new message, populate from and subject fields, and message text Outlook VBA and Custom Forms 1
G Macro: Create New Message and Auto populate To Field Outlook VBA and Custom Forms 5
S populate body with Word data Outlook VBA and Custom Forms 7
L how to populate multiple users contacts Outlook VBA and Custom Forms 9
A Populate task field based on value of other field Outlook VBA and Custom Forms 9
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
V Outlook Form ListBox is not editable Outlook VBA and Custom Forms 2
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
Witzker Outlook 2019 How to get a Photo in a User Defined Contact form Outlook VBA and Custom Forms 2
Witzker Place cursor at opening, a user defined OL contact form Outlook VBA and Custom Forms 2
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
