Will not Install
  • Thread starter Thread starter Anthony
Anthony
I've just joined MS Empower and as a database consultant wanted to give
Business Contacts Manager a whirl especially as it will integrate with the
Accounting software, however I can't seem to get the wretched thing to
install. I've tried it on a new laptop with vista home premium and office
ultimate. Setup Failed please check log file. Then tried it on my desktop
Vista Ultimate with Office 2007 Enterprise.
Does anyone know how to get this to install, I've tried with accounting
first removed accounting and SQL and then installing it and I still can't
seem to get it to work.
I downloaded the version through the MSDN thing.
Any help gratefully received.
Thanks once again
Ant
Check your log file. I had the same issue, and found the problem was that
Vista locked a file that the installer was trying to modify. I believe that
file was MAPISVC.INF located in the System 32 subfolder. I had to install a
freeware program called Unlocker to change the name of the file, and then
change it back. After that, BCM installed just fine.
Michael
"Anthony" <Anthony> wrote in message
news:0C15D31A-835C-4582-92DB-B866E416C5B8@microsoft.com...
> Thanks once again
> Ant
Michael,
I had the same problem, but I am on WinXP and do not have that .inf file in
Windows\System32...
Thoughts?
JMan
> > Michael
> > Thanks once again
> > Ant
On Apr 15, 3:14 pm, "Michael Ray Brown"
> Vista locked a file that the installer was trying to modify.  I believethat
> > Michael
> "Anthony" <Anth...> wrote in message
> > Thanks once again
> > Ant- Hide quoted text -
> - Show quoted text -
Generally a reboot should unlock files. Unless something like the
search indexer or activesync service is always locking that file.
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
e_a_g_l_e_p_i I can't believe what I am seeing when trying to install Outlook 2021 Using Outlook 9
R Unable to install without email account Using Outlook 4
J Install BCM Client without an local SQl Database BCM (Business Contact Manager) 6
Chris Grew How Long To Install BCM BCM (Business Contact Manager) 2
icacream reinstall outlook after new install win7 Using Outlook 2
R Cannot Install Outlook Invalid XML Using Outlook 2
B OL2010 and install custom WYWO form Using Outlook 1
D 2013 BCM Won't Install BCM (Business Contact Manager) 1
S Recover Autocomplete After Computer Failure Re-install Using Outlook 3
T Office2013 and BCM on Windows 8.1 -- install of BCM does not work? BCM (Business Contact Manager) 2
A how to install or enable categories in OL 2013 for calendar and contacts Using Outlook 5
O RE-install of BCM and previous sync profile conflicts BCM (Business Contact Manager) 3
D Can't install here Using Outlook 3
J Office + Outlook 2013 installed, but I need to install Outlook 2010 Using Outlook 2
C VBA problem in new install Using Outlook 3
B Can't install Calendar Printing Assistant - Windows 7 64bit&Office 2010 32bit Using Outlook 2
S BCM Install Issues BCM (Business Contact Manager) 2
L Cannot install BCM 2010-"Outlook 2010 Not Installed" but it is! BCM (Business Contact Manager) 1
T BCM Install fails Both w Off. Pro 2010 Beta & on reinstall Off.Pro BCM (Business Contact Manager) 5
T Install BCM on SBS 2008 Standard server BCM (Business Contact Manager) 1
M OL2007 Add-in won't install on OL2010 Outlook VBA and Custom Forms 1
D BCM install problem on Win7 BCM (Business Contact Manager) 3
D business contact manager did not install with outlook 7 BCM (Business Contact Manager) 2
S Trying to install BCM 2010 x64, getting error BCM (Business Contact Manager) 8
E Install BCM on windows 7 BCM (Business Contact Manager) 2
H Fail to install BCM 2007 (English) on Windows 7 64 bit (Danish) BCM (Business Contact Manager) 3
S Failed to install Business Conctact Manager 2007 BCM (Business Contact Manager) 1
R RE: Business Contact manager failed to install BCM (Business Contact Manager) 1
S Business Contact Manager 2007 won't install with Windows 7 BCM (Business Contact Manager) 3
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
T Can I install BCM on 2 computers w/o buying 2 copies? BCM (Business Contact Manager) 1
S BCM in Office Ultimate 2007 Won't Install on W7 Ultimate 32 BCM (Business Contact Manager) 1
K Unable to install business Contact Manager. BCM (Business Contact Manager) 1
M How do I install Outlook 2007 Business Contact Manager on Win7x64 BCM (Business Contact Manager) 1
A What to do if BCM didn't install with 2007 Professional Trial? BCM (Business Contact Manager) 1
M Install problem on Windows 7 BCM (Business Contact Manager) 2
J Install BCM on Windows Vista BCM (Business Contact Manager) 3
H Failed install BCM (Business Contact Manager) 2
S BCM install fails at SQL install BCM (Business Contact Manager) 1
M How to install custom mapi form programmatically? Outlook VBA and Custom Forms 1
