Original Attachment not removed
  • Thread starter Thread starter sd
sd
hello
I've VSTO Addin for Outlook 2007.
I'm adding a dummy attachment in BeforeAttachment event & removing
original attachment.
But the attachment list still shows me original attachment along with
dummy attachment.
Besides this when I drag drop or insert attachment the cursor position
changes.
I also need to insert a link at current cursor position.so the cursor
position should not change
for proper link insertion.
Below is the code I'm using -
strMyTmpFilePath = IO.Path.Combine(strMyTmpFilePath,
strMyTmpFileName)
IO.File.AppendAllText(strMyTmpFilePath, "this is a dummy
file")
CurrentMailItem.Attachments.Add(strMyTmpFilePath)
IO.File.Delete(strMyTmpFilePath)
Cancel = True
'Code to add Link at cursor position
Dim ObjSel As Object = CurrentInsp.WordEditor.Application.Selection
With ObjSel
Dim Rg As Object
> MoveRight(Unit:=2, Count:=1) 'wdWord=2
Rg = .range
> Hyperlinks.Add(Anchor:=Rg, Address:=strAttachmentURL _
, TextToDisplay:=strNewLink.ToString)
> InsertAfter(" ")
If Rg IsNot Nothing Then Marshal.FinalReleaseComObject(Rg)
If ObjSel IsNot Nothing Then Marshal.FinalReleaseComObject(ObjSel)
Try saving the item after you add your new attachment and again after you
remove the old one.
"sd" <dshubhangi@gmail.com> wrote in message
news:615ab412-3a80-4272-9f4d-b930ba2974c8@b25g2000prb.googlegroups.com...
> hello
> dummy attachment.
> changes.
> strMyTmpFileName)
> file")
> Cancel = True
> With ObjSel
> Dim Rg As Object
> .MoveRight(Unit:=2, Count:=1) 'wdWord=2
> Rg = .range
> .Hyperlinks.Add(Anchor:=Rg, Address:=strAttachmentURL _
> .InsertAfter(" ")
> End With
> Thanks
Thanks Ken
I saved item after new attachment addition & also after removing the
old one.But no success.Attachment list not refreshed.
Also I don't want to save item (if the user cancels send then I will
have to remove this item from drafts).I reassigned the body
format,that refreshes the attachment list.But in plain text mode link
is not recognized (it is displayed as plain text) & cursor position
again set to starting of message body .
Is there any way so the link gets recognized & also cursor position
doesn't change? If I don't add new attachment ,just remove the old
one & add the link then there is no problem link is recognized &
cursor position also not changed.
I don't know about forcing a refresh as well as not changing the cursor
position. However, that's not really an issue, since you can always get the
cursor position first before it changes. That should help.
See if faking out Outlook helps, something like item.Body = item.Body. But I
think you're going to have to save. I usually use a flag in those cases,
first I check the Saved property and then I flag my save if needed, then I
handle the Write() event on the item and if I didn't fire that event by
saving it's the user who did it (or auto-save). Then I can work out if I
need to delete the item from Drafts if necessary.
news:3d84b636-4781-4edb-82ff-21e2f8edfdf2@l35g2000pra.googlegroups.com...
> Thanks Ken
A Creating a rule that both forwards the original attachment and uses a template Using Outlook 11
S Email Generated from another program and then edited sends original email. Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
B disappearing original when attach to email Using Outlook 1
F Move mails from Deleted Items folder back to its original folder where the mails got deleted Using Outlook 0
Diane Poremsky Foward a Message and CC the Original Recipients Using Outlook 0
H send reminder if no reply received on first or original email using macro Using Outlook 2
oliv- Why custom form is different from original ipm.contact ? Outlook VBA and Custom Forms 4
S Reply & Forward Date in original message incorrect Using Outlook 2
E Button in body of email to approve/reject with original text Using Outlook 1
S Need CC: to show the original To: recip[ients Using Outlook 4
R Forwarding and keeping Original intact Using Outlook 3
B Auto reply using macro include original email Using Outlook 4
J Image in original e-mail is hyperlinked when a reply with the image is hyerplinked Exchange Server Administration 1
J Adding original email text to outlook message template Outlook VBA and Custom Forms 2
L Creating a Task from Email and Attaching Original Email Outlook VBA and Custom Forms 6
L Auto Forward without presenting the original sender Outlook VBA and Custom Forms 1
J How to redesign the Contact form without losing the original layout? Using Outlook 2
A automatically remove flag from original message when a response was received Using Outlook 2
C Remove iCloud so I can have original outlook calendar and contacts Using Outlook 43
C Hover display of DL shows original owner, not current Using Outlook 2
S Outlook 2k/2k3 Reply or Forward: Signature image replaced by original sender Using Outlook 3
M 2010: sorting by ORIGINAL send date Using Outlook 1
C Create a rule to only check new content in email - disregard original content Using Outlook 3
R Recall Email Message when i'm not the original sender - Outlook 2010 Using Outlook 2
C Outlook/Exchange 2010 Recover Deleted Items to original folder Using Outlook 2
P Reply to original sender, not to forwarder ? Outlook VBA and Custom Forms 1
S -> [O2007]: get the message HTML original source code? Outlook VBA and Custom Forms 6
R Auto Reply with Original Email and any attachments Outlook VBA and Custom Forms 1
R keep track of the original sender Outlook VBA and Custom Forms 3
A Strange Attachment Behavior Using Outlook 9
S Paperclip icon shows without attachment in email under Sent folder Using Outlook 0
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 4
Timmon Remove just one attachment before AutoForward Outlook VBA and Custom Forms 0
