problem with transparency in custom icons.
  • Thread starter Thread starter Saeed
Saeed
I am facing problem while adding custom icons to CommandBarButton in toolbar.
I have icons which are in png format with transparency. For showing them I
have created mask with black and white pixels and set button.picture to png
icon and button.mask to the mask png. I am able to see the icons.
The problem here is with pixels in icon which are semi-transparent (alpha>0
but <255) like shading in the boundary. What should be
the color of mask for those pixels. If I make it white, I cant see those
pixels. If I make it black, those pixels look in a dark color most likely
because the background has now become visible.
Are the semi-transparent pixels allowed in the icon.
Semi-transparent pixels aren't supported. In fact the spec for a command bar
button image is 16x16 pixels with 8-bit color in a BMP file. Anything else
may or may not display correctly.
"Saeed" <Saeed> wrote in message
news:7871DB86-A3C0-48E3-AD92-E77A878296FA@microsoft.com...
> toolbar.
> png
> (alpha>0
Are transparent and semi transparent pixel images supported as Ribbon button
icons, as I do not see any mask kind of thing for adding transparency in
ribbon icons. I am adding ribbon button using xml file and providing icon
using getImage callback.
> >toolbar.
> > png
> > (alpha>0
For the ribbon the transparency is stored in the alpha layer of the image.
Usually the best results are from PNG files.
news:5BAE6024-CD28-483A-9328-2AC94BB29C31@microsoft.com...
> button
