Context Menu Question
  • Thread starter Thread starter John Erickson
Thanks for immediate response again.
I tried searching for my menu items in Update event(as reseting the menu bar
should update commandbars collection.)
and when i don't find them, i create them again but still same problem
remains.
wrote:
> Don't assume the UI is there. Test for it and if it's not there re-create it
> again.
> "nikhil" <nikhil> wrote in message
> news:B611CACB-B28B-48BC-B576-1893B7335F5C@microsoft.com...
> > Hello,
> > Thanks for the reply.
> > yes i am referring to the menu items which i inserted into Tools menu.
> > i am calling put_enabled(VARIANT_FALSE), which eventually fails, because
> > of
> > absence of menu items,thats alright.And i am creating my UI in the first
> > activate event of explorer window(not inspector window).
> > is this problem already present in outlook2000 ?(like the one of context
> > menu )
> > i am not getting why this is happening.
I don't know. I've used the code for context menus hack a couple of times
and never had a problem with it, but that was a long time ago.
This isn't with Outlook 2000 in Internet only mode, is it? That mode was so
broken that most of us stopped supporting it almost immediately.
All I can say is that the context menu hack for Outlook 2000 was completely
unsupported and always prone to blow up.
news:1754FA70-1896-43F8-918F-D2A3E82ADDDF@microsoft.com...
> Hello,
> bar
> remains.
A Missing context menu on Location field Using Outlook 2
R What happen to 'View Attachments' context menu item in Outlook 2010? Using Outlook 6
S Ad Context Menu in Outlook 2007 Outlook VBA and Custom Forms 1
T Context menu for new message window Outlook VBA and Custom Forms 7
T Outlook 2010 context menu changes Outlook VBA and Custom Forms 3
H email editor context menu 2007. Outlook VBA and Custom Forms 1
C Event Capture - Item Context Menu (Delete). Can you hook it? Outlook VBA and Custom Forms 1
D Outlook missing Open With Context Using Outlook 1
R Outlook ribbon menu default? Using Outlook 7
N Which Button Was Clicked on the Ribbonbar Menu Outlook VBA and Custom Forms 2
N Multiple instances of Outlook on Start Menu Using Outlook 2
E Searching a Shared Outlook Mailbox from the start menu? Using Outlook 4
L Add to Right Click Menu Using Outlook 10
R Missing Backup command in File menu after installing pfback.exe Using Outlook 2
P Cannot open Options Menu Outlook 2007 and Cannot create a new profile Using Outlook 0
M Missing New Menu Option in Outlook 2010 Using Outlook 0
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
C Tasks > Field Chooser > Fields with dropdown menu (eg. Status). How to custom? Using Outlook 6
T Outlook 2003 menu graphical glitch Using Outlook 5
S Removing "Research" menu item Outlook VBA and Custom Forms 1
M Files in "Attach File" popup menu no longer alphabetical Using Outlook 3
A disable a menu in active inspector Outlook VBA and Custom Forms 1
Z Right click menu Outlook VBA and Custom Forms 4
A Extending Presona Menu in Outlook Outlook VBA and Custom Forms 9
M How to get the preview pane handle, when it is created with menu c Outlook VBA and Custom Forms 1
C Cannot access macro menu in OL2003 Outlook VBA and Custom Forms 2
H access appointmentItem from ribbon menu Outlook VBA and Custom Forms 1
U Adding multiple menu Items. Problems handling the click events Outlook VBA and Custom Forms 1
R Errors while adding new item to main menu Outlook VBA and Custom Forms 4
S I have a Question on location of a Custom Outlook menu for my ADDI Outlook VBA and Custom Forms 1
S Question of setting the order of a custom menu in Outlook Outlook VBA and Custom Forms 1
S Thank you Diane, Plus pst files question Using Outlook 8
J Outlook inbox question Using Outlook 4
D.Moore Preview pane question Outlook VBA and Custom Forms 3
D.Moore Outlook desktop client suggested searches question Using Outlook 22
e_a_g_l_e_p_i Question about Outlook 2021 and Gmail Using Outlook 8
G Question marks in messages Using Outlook 2
e_a_g_l_e_p_i Question about calendar Using Outlook 5
e_a_g_l_e_p_i Question about installing my Gmail account on my iPhone but still getting messages downloaded to my desktop Outlook. Using Outlook 3
e_a_g_l_e_p_i Question about reinstalling Outlook 2021 Using Outlook 5
e_a_g_l_e_p_i question about 2-Step Verification with my gmail Using Outlook 0
D Question on removing an alias Using Outlook 1
