Works in Word but not Outlook. Plz Help!
  • Thread starter Thread starter TKM
TKM
I have a button that reads..
RetVal = Shell("cmd.exe /k """"c:\program
files\netinst\niinst32.exe"",/Execute:{189BF48719-4BCA-4332-9C3E-F98UYTVBN6A86} /install""""")
It works fine in a Word .doc however when I cut and paste the entire doc
into Outlook 2003. It will not work. The "Links" I have on the document work
fine but the button does not. Any ideas why? Thanks in advance
Outlook messages don't run code. Please stick to your original discussion
thread, rather than starting a new one.
Sue Mosher
"TKM" <TKM> wrote in message
news:C0717386-E6EA-417E-83E4-577A813CC6FD@microsoft.com...
> /install""""")
> work
D Using VBA to send Word document as body of message works in 2007, but not in 2003 Outlook VBA and Custom Forms 9
P Outlook 2013 search no longer works Using Outlook 2
KeithJB iCloud calendar sync only works one way! Using Outlook 3
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
A Manually Building DisplayName <emailaddr> No Longer Works Using Outlook 0
N .StartDate & .EndDate Only Works Sometimes Outlook VBA and Custom Forms 1
U Keyboard Remapper no longer works in Outlook Using Outlook 1
R Email account works on thunderbird not Outlook Using Outlook 6
T 2 mostly identical scripts, only one works Using Outlook 16
David Michaels VB coding works in OL 2010, but not in OL 2013 Outlook VBA and Custom Forms 4
D Default Send Account that Works? Using Outlook 0
J Cached mode no longer works with NTLM authentication Exchange Server Administration 0
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
R SEARCH PEOPLE - would like one that really works Using Outlook 1
B Display of Sending Account in Outlook 2007 no longer works Using Outlook 2
S Outlook no longer works with Yahoo Mail Using Outlook 9
E Need a bit of education on how Outlook works please Using Outlook 3
P Outlook works, but freezes when trying to use calender v2007 (vista prof) Using Outlook 1
B Outlook connector only works when set to default Using Outlook.com accounts in Outlook 5
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
X Outlook 2010 - search works on one system but not other - identical configurat Using Outlook 2
N Filter end date works differently in OL'07/OL'10 vs OL'03? Hello?! Using Outlook 12
J Outlook Connector only works for a day?! Using Outlook.com accounts in Outlook 3
R Password not accepted but works when saved. Using Outlook 3
T Unable to edit Distribution Group membership via Outlook (works via ECP). Exchange Server Administration 7
J Unable to access public folders in Outlook 2007 on Exchange 2010. OWA PF works fine Using Outlook 7
R BCM works, but everything else stopped working BCM (Business Contact Manager) 1
C Copy email to different folder, works in 2003 but not 2007 Outlook VBA and Custom Forms 3
B Email Autolink Works Sporadically BCM (Business Contact Manager) 2
J Outlook, Word, Access crash unless run in Admin mode - time dependent it seems Using Outlook 10
V Embedding hyperlink into Word document Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
C blocking two or more word domains separated by period/dot Using Outlook 3
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
Diane Poremsky Use Word Macro to Apply Formatting to Email Using Outlook 0
iwshim word shortcut to search outlook Using Outlook 3
C Outlook 2016 - converting Word VBA to default Outlook message Outlook VBA and Custom Forms 0
C Merging Word and Access into Outlook Using Outlook 4
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
