If Item.senderemailaddress Problem
  • Thread starter Thread starter Jeff C
Jeff C
I have been trying alternatives to the code below with no luck at all. The
code works fine but am trying to add the if condition to only BCC the strBCC
if I am using my Send As account in the exchange. Can anyone point me in the
right direction? I think I am just missing something here. Thanks
Private Sub Application_ItemSend(ByVal Item As Object, _
Cancel As Boolean)
Dim objRecip As Recipient
Dim strMsg As String
Dim res As Integer
Dim strBcc As String
#### USER OPTIONS ####
address for Bcc -- must be SMTP address or
resolvable
to a name in the address book
strBcc = "MySendAsMailAddress"
If Item.SenderEmailAddress =
"mysendasmailaddress.com" Then
Set objRecip = Item.Recipients.Add(strBcc)
objRecip.Type = olBCC
If Not objRecip.Resolve Then
strMsg = "Could not resolve the Bcc
recipient. " & _
"Do you want still to send the
message?"
res = MsgBox(strMsg, vbYesNo +
vbDefaultButton1, _
"Could Not Resolve Bcc Recipient")
If res = vbNo Then
Cancel = True
Set objRecip = Nothing
Jeff C
Live Well .. Be Happy In All You Do
Outlook version? By "Send As account," do you mean that you're sending as
another Exchange user? If so, try looking at the value of the SentOnBehalfOf
property.
Sue Mosher
"Jeff C" <JeffC> wrote in message
news:C796BE86-B833-4BE0-8EF9-D7541F6630E9@microsoft.com...
> strBCC
> the
> Cancel As Boolean)
> Dim res As Integer
> On Error Resume Next
> resolvable
> recipient. " & _
> message?"
> vbDefaultButton1, _
> If res = vbNo Then
> Cancel = True
> End If
> End If
> End If
> End Sub
Jeff C
> property.
I am using Outlook 2003 with all the service pack updates in a corporate
exchange server. Thank you so much - your suggestion works great!
This solves many issues with organizing SendAs mail from a generic mailbox.
> > Sue Mosher
> > strBCC
> > the
> > Cancel As Boolean)
> > Dim res As Integer
> > resolvable
> > recipient. " & _
> > message?"
> > vbDefaultButton1, _
> > If res = vbNo Then
> > Cancel = True
> > End If
> > End If
> > End If
> > End Sub
Jeff C
> property.
This suggestion works in Outlook 2003 but not in Outlook 2007, what changes
need to be made?
> > Sue Mosher
> > strBCC
> > the
> > Cancel As Boolean)
> > Dim res As Integer
> > resolvable
> > recipient. " & _
> > message?"
> > vbDefaultButton1, _
> > If res = vbNo Then
> > Cancel = True
> > End If
> > End If
> > End If
> > End Sub
In Outlook 2007, what value do you see for SentOnBehalfOf?
Sue Mosher
news:82C2B0EC-DC1A-498F-BC88-5758FC24854F@microsoft.com...
> changes
> need to be made?
> > SentOnBehalfOf
> > property.
> > >The
> > > strBCC
> > > in
> > > the
> > > Cancel As
> > > Boolean)
> > > Dim res As Integer
> > > resolvable
> > > recipient. " & _
> > > message?"
> > > vbDefaultButton1, _
> > > Recipient")
> > > If res = vbNo Then
> > > Cancel = True
> > > End If
> > > End If
> > > End If
> > > End Sub
Jeff C
With the code being in "thisoutlooksession" module, I can't figure out how
to view that value. Been searching for differences on this between the two
versions, Outlook 2003 vs 2007 and can't find a reference. Any more
assistance would be appreciated.
> > Sue Mosher
> > changes
> > need to be made?
> >> SentOnBehalfOf
> >> property.
> >> >The
> >> > strBCC
> >> > in
> >> > the
> >> > Cancel As
> >> > Boolean)
> >> > Dim res As Integer
> >> > resolvable
> >> > recipient. " & _
> >> > message?"
> >> > vbDefaultButton1, _
> >> > Recipient")
> >> > If res = vbNo Then
> >> > Cancel = True
> >> > End If
> >> > End If
> >> > End If
> >> > End Sub
Check the value of Item.SentOnBehalfOfName (sorry, I got the property name
wrong earlier, but you could have looked it up in the object browser) using
any of the standard VBA techniques that you'd use to check the value of an
expression: Set a watch variable, use Debug.Print or MsgBox, use a
breakpoint, etc.
Sue Mosher
news:93A303BC-D658-4809-8554-1D55DD3F3E20@microsoft.com...
> two
> > > changes
> > > need to be made?
> > >> as
> > >> SentOnBehalfOf
> > >> property.
> > >> >all.
> > >> >The
> > >> > the
> > >> > strBCC
> > >> > me
> > >> > in
> > >> > the
> > >> > Cancel As
> > >> > Boolean)
> > >> > Dim res As Integer
> > >> > or
> > >> > resolvable
> > >>> >> > Set objRecip =
> > >> > recipient. " & _
> > >> > the
> > >> > message?"
> > >> > vbDefaultButton1, _
> > >> > Recipient")
> > >> > If res = vbNo Then
> > >> > Cancel = True
> > >> > End If
> > >> > End If
> > >> > End If
> > >> > End Sub
Jeff C
Well, the code using
If Item.SentOnBehalfOfName="DisplayName" then
Works perfectly in Outlook 2003. I've tries it every which way in 2007
including using the Alias, and the actual email address without any luck.
Any other ideas? Than you.
> Sue Mosher
> > changes
> > need to be made?
> >> SentOnBehalfOf
> >> property.
> >> >The
> >> > strBCC
> >> > in
> >> > the
> >> > Cancel As
> >> > Boolean)
> >> > Dim res As Integer
> >> > resolvable
> >> > recipient. " & _
> >> > message?"
> >> > vbDefaultButton1, _
> >> > Recipient")
> >> > If res = vbNo Then
> >> > Cancel = True
> >> > End If
> >> > End If
> >> > End If
> >> > End Sub
Still waiting for an answer to my question: If the value of
SentOnBehalfOfName isn't "DisplayName," then what is it? That may indicate
your next step.
Sue Mosher
news:D4A48193-A412-4C80-912C-3242266CCD20@microsoft.com...
> > > changes
> > > need to be made?
> > >> as
> > >> SentOnBehalfOf
> > >> property.
> > >> >all.
> > >> >The
> > >> > the
> > >> > strBCC
> > >> > me
> > >> > in
> > >> > the
> > >> > Cancel As
> > >> > Boolean)
> > >> > Dim res As Integer
> > >> > or
> > >> > resolvable
> > >>> >> > Set objRecip =
> > >> > recipient. " & _
> > >> > the
> > >> > message?"
> > >> > vbDefaultButton1, _
> > >> > Recipient")
> > >> > If res = vbNo Then
> > >> > Cancel = True
> > >> > End If
> > >> > End If
> > >> > End If
> > >> > End Sub
G Outlook Contact Item.Restrict where FullName is NULL Outlook VBA and Custom Forms 3
T Outlook365 search item listed as "potential matches" can't be opened Using Outlook 0
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
S Command Button_Click action on Item/Reminder Outlook VBA and Custom Forms 3
T Pictures degrade each time an Outlook item is edited and re-saved Using Outlook 1
GregS Many Sent Item folders Using Outlook 3
B Select / activate first email item in the searched query Using Outlook 1
N "Discussion" item Using Outlook 3
Peter H Williams How to Move Mail item after processing Outlook VBA and Custom Forms 5
M Shortcut to another outlook item Using Outlook 0
Cdub27 Your changes to this item couldn't be saved because Server Denied Operation (HTTP 403 Forbidden) Using Outlook 1
G Outlook item link Using Outlook 0
D Save Sent Item to Using Outlook 0
Jeanne Goodman Delete Calendar Item Bypassing Deleted Items folder Outlook VBA and Custom Forms 2
Diane Poremsky Display the Created Date field of any Outlook item Using Outlook 0
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item Using Outlook 0
Z Item.Recipients for Task Assignment on Send Outlook VBA and Custom Forms 10
J "This item has been changed still want to delete it" message Using Outlook 3
oliv- HIDE ITEM Outlook VBA and Custom Forms 3
D Shared Mailbox with mail item marked as "private" Using Outlook 0
Diane Poremsky Change Item Count on All Folders in a Data File Using Outlook 0
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
V Locate item Account Outlook VBA and Custom Forms 7
