Another way to detect if email read?
  • Thread starter Thread starter Mark B
Mark B
VSTO, 2007, C#.
I'm going through the code of our senior developer to try and reduce the
load-time of the Outlook Add-on.
I see he is adding an event handler to all email items on ThisAddIn_Startup
so he can detect when an email is read. (He uses this info for something
else we need). It all works fine but I have noticed in testing it gets
pretty slow as more emails are stored in Outlook. I've got around 50 and the
delay is too long already...
He did have one for On-Email-Send but I removed that code and put a "folder
watch" event on the SentItems folder instead.
I am just trying to think of any way I can do something similar or an
alternative for detecting if an email is read. Any ideas?
private void ThisAddIn_Startup(object sender, System.EventArgs e)
Outlook.Stores stores =
Globals.ThisAddIn.Application.GetNamespace("MAPI").Stores;
foreach (Outlook.Store store in stores)
foreach (Outlook.Folder f in store.GetRootFolder().Folders)
foreach (object i in f.Items)
if (i != null && i is Outlook.MailItem)
EmailsEventHandler.AddHandlers((Outlook.MailItem)i);
public static bool AddHandlers(Outlook.MailItem mail)
bool result = true;
readEventHandlers.Add(new EmailReadEventHandler(mail));
return result;
Have you considered using the Application.ItemLoad event along with a
wrapper class to handle multiple items being loaded?
Sue Mosher
"Mark B" <none123@none.com> wrote in message
news:e5I0eJoYKHA.2164@TK2MSFTNGP02.phx.gbl...
> VSTO, 2007, C#.
> ThisAddIn_Startup so he can detect when an email is read. (He uses this
> info for something else we need). It all works fine but I have noticed in
> testing it gets pretty slow as more emails are stored in Outlook. I've got
> around 50 and the delay is too long already...
> "folder watch" event on the SentItems folder instead.
> bool result = true;
> return result;
No but I wonder if that handles the email being read in the preview pane
though. Think it would? I think a lot of people just use that these days to
read emails.
"Sue Mosher [MVP]" <suemvp@gmail.com> wrote in message
news:%23vPbtNoYKHA.1640@TK2MSFTNGP06.phx.gbl...
> > Sue Mosher
> > VSTO, 2007, C#.
> > got around 50 and the delay is too long already...
> > bool result = true;
> > return result;
Standby -- just reading your book:
http://books.google.co.nz/books?id=...e&q=outlook 2007 Application.ItemLoad&f=false
news:ugJ2XWoYKHA.1652@TK2MSFTNGP05.phx.gbl...
> to read emails.
>> > > Sue Mosher
> >> VSTO, 2007, C#.
> >> in testing it gets pretty slow as more emails are stored in Outlook.
> >> I've got around 50 and the delay is too long already...
> >> bool result = true;
> >> return result;
Yes, I think that's one of the reasons it was added -- to provide a better
way to handle that event.
Sue Mosher
> to read emails.
> >> VSTO, 2007, C#.
> >> bool result = true;
> >> return result;
Thanks for your help Sue. I've coded it now and it works well.
news:eRO341tYKHA.5640@TK2MSFTNGP06.phx.gbl...
> > Sue Mosher
> > to read emails.
> >>> VSTO, 2007, C#.
> >>> the load-time of the Outlook Add-on.
> >>> bool result = true;
> >>> return result;
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
C Copy from one Profile to another Using Outlook 0
B Move emails from one account to another Outlook VBA and Custom Forms 2
R Clear one category when another is chosen Outlook VBA and Custom Forms 1
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
e_a_g_l_e_p_i Is it possible to transfer things from one calendar to another Using Outlook 2
S Email Generated from another program and then edited sends original email. Using Outlook 2
R Time for another article on contact cards? Using Outlook 0
M Moving mail to another folder is much slower than before (Office365) Using Outlook 0
B Moving account, contacts & emails to another H/D with MSOutlook Using Outlook 5
M Shortcut to another outlook item Using Outlook 0
M FW Email via Outlook and another requirement Outlook VBA and Custom Forms 1
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
D Unable to Send On Behalf of Another User Exchange Server Administration 0
D EXPORTING MS EXCHANGE EMAILS to another platform Exchange Server Administration 10
mrmmickle1 UserProperties VBA to move message to another folder Outlook VBA and Custom Forms 7
P Office 365 manage another person's calendar Using Outlook 0
TheDavidSlight Daylight savings - another subtle bug ... Using Outlook 3
C Custom Application Form send Email to Another User Using Outlook 1
A Calling one module from another Outlook VBA and Custom Forms 2
M How to duplicate content of one field in another field? Outlook VBA and Custom Forms 3
iwshim Transfering mail from the outbox to another computer Using Outlook 0
I Outlook 2010 Replicating mixed PST/OST profile to another desktop Using Outlook.com accounts in Outlook 1
J Macro for replying to One Email with another Using Outlook 1
wallisellener Another BCM Authentication thread BCM (Business Contact Manager) 5
mikecox Forward email to another address; not with Rules Using Outlook 3
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
