How to set a contact's emailaddress1, emailaddress2, emailaddress3?
  • Thread starter Thread starter ryotyankou
ryotyankou
I want to update the contact's info or create new contact with emailaddress1,
emailaddress2 and emailaddress3. For new contact, i use IAddrBook::
CreateOneOff, it works great. But i don't know how to update the three
emailaddress, for example: user can set the following combine for three
emailaddresses.
1. None. No emailaddress will be set.
2. First only first emailaddress will be set.
3. Second //no need for explaination, right :)
4. Third
5. First && Second
6. First && Third
7. Second && Third
8. First, Second and Third
I tried to use SetProps and pass empty string in, the contact's emailaddress
will be empty, it's ok, but the associated entry in addressbook is still
there.
Do i need to DeleteEntries to remove it?
Another question, whether an IMessageStore can only have one Addressbook? I
don't quite understand the difference between GetDefaultDir and GetPAB.
(Default DIR and PAB).
Thanks in advance.
200911
Are you setting these properties on teh IMailUser object returned by the OAB
address book provider or teh underlying IMessage in one of the contacts
folders?
Dmitry Streblechenko (MVP)
"ryotyankou " <u48591@uwe> wrote in message
news:9f3ddc267280b@uwe...
> emailaddress1,
> emailaddresses.
> 4. Third
> 5. First && Second
> 6. First && Third
> 7. Second && Third
> emailaddress
> there.
> I
> Thanks in advance.
> 200911
Take no care about which interface i used to set these properties, would you
please tell me how to update them to reach my purpose in both situations(the
IMailUser and IMessage). TIA.
> folders?
> >emailaddress1,
> [quoted text clipped - 20 lines]
> > Thanks in advance.
200911
Another questions, What's the difference between PAB and default Directory?
And whether a message store can only have one addressbook? Thank you.
> folders?
> >emailaddress1,
> > Thanks in advance.
? It makes all the difference in the world how you access these objects.
news:9f4721fc54a07@uwe...
> you
> situations(the
> >OAB
> >folders?
> >>emailaddress1,
> >> Thanks in advance.
> 200911
IAddrBook::GetPAB returns the container used to keep the personal contacts
in.
IAddrBook::GetDefaultDir returns the entry id of the contains that is
selected by default when you open teh adderss book window.
Message stores do not have any address books. You are confusing address
books with one particular address book provider (OAB) that happens to use
IPM.Contact messages as a storage for its address book objects (IMailUser).
news:9f4798c0684ce@uwe...
> Directory?
> >OAB
> >folders?
> >>emailaddress1,
> >> Thanks in advance.
OK, i will describe how did i get the contact info.
1. Use IAddrBook::GetSearchPath get SRowSet.
2. Use PropFindProp check SRowSet for PR_ENTRYID.
3. Use IAddrBook::OpenEntry open the entry id to get IABContainer.
4. Use IABContainer::GetContentsTable to get contact table.
5. Then i get wanted items in table and save their entry ids.
> .....after some operation, for example, show UI, let user make choose, etc.
In a word, i use the entry id find here to operate the contact.
My code is describe as follow:
1. ISession::OpenEntry(entry id) to get IMessage. //here should make a
conversion from CONTAB_ENTRYID to ENTRYID, for the entry id i got above is
CONTAB_ENTRYID, right??
2. use IMessage::SetProps to set
lNameId[0] = PID_LID_EMAIL1_ADDR_TYPE;// or EMAIL2/EMAIL3
lNameId[1] = PID_LID_EMAIL1_EMAIL_ADDRESS;
lNameId[2] = PID_LID_EMAIL1_ORIGINAL_DISPLAY_NAME;
lNameId[3] = PID_LID_EMAIL1_ORIGINAL_ENTRY_ID;//Use CreateOneOff create and
get entry id,
IMessage::SaveChange to save item.
This is only work for create new emailaddress and update existing
emailaddress.
For example, use want to set:
1. Before set:
we have : test1@test.com(emailaddress1)
we want to set it as: test111@test.com(emailaddress1)
OK, we can update existing emailaddress.
2. Before set:
we have: test1@test.com(emailaddress1)
we want to set it as: test1@test.com(emailaddress1), test2@test.com
(emailaddress2)
OK we can create new.
3. Before set:
we want to set it as: test2@test.com(emailaddress2)
That's mean we want to remove
emailaddress1.
ACTUAL RESULT IS: test1@test.com(emailaddress1), test2@test.com
(emailaddress2)
The code cannot work in situation 3.
In a word, i don't know how to remove existing emailaddress. Are we clear?
> > you
> [quoted text clipped - 12 lines]
> >>> Thanks in advance.
200911
My purpose is quite simple, as there is a contact(See how did i get its entry
id in other reply of this post), I Create an UI, user can change
Emailaddress1, Emailaddress2 and Emailaddress3 for this contact on the UI. If
user clear any one of them, that means user want to remove it in addressbook,
otherwise create new or update existing ones.
> in.
> > Directory?
> [quoted text clipped - 10 lines]
> >>> Thanks in advance.
200911
Can you help me please, dmitry?
> >in.
> [quoted text clipped - 9 lines]
> >>>> Thanks in advance.
200911
So if you want to remove an address, you would need to delete the
appropriate properties from the IPM.Contact message using
IMessage::DeleteProps().
news:9f53f26c4c447@uwe...
> etc.
> and
> get entry id,
> emailaddress.
> 1. Before set:
> emailaddress.
> 2. Before set:
> (emailaddress2)
> 3. Before set:
> emailaddress1.
> (emailaddress2)
> >> you
> >>>> Thanks in advance.
> 200911
Witzker Macro to set contact reminder to next day 9:00 Outlook VBA and Custom Forms 45
P Last Change attribute set after viewing a public folder contact Exchange Server Administration 0
B Outlook contact, calendars, and tasks wont set up in icloud Using Outlook 4
M suddenly cannot set outlook 2007 contact reminders Using Outlook 2
G how to set contact custom form as default contact form? Using Outlook 7
K Set "Assigned To" for a Contact Item Outlook VBA and Custom Forms 5
A Outlook 365 Can I set up a Microsoft 365 account to capture emails sent and received from a comcast.net account? Using Outlook 7
efire9207 Set all properties Using Outlook 1
T How to set Default FONT for Email composing ? Using Outlook 0
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
F how do i set a reminder in onenote 2010 Using Outlook 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
O Set columns for all (sub)folders Using Outlook 8
e_a_g_l_e_p_i How to set fonts for emails in all folders in Outlook Using Outlook 1
F Set (flagged) reminder for next business day Using Outlook 4
L how to set downloaded cached emails Using Outlook 5
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge Using Outlook 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
