Passing values from custom form into another form's text box
  • Thread starter Thread starter bear
bear
I have a custom form that can be accessed as part of creating a new appointment in the calendar. Custom form is a second tab.
How would one take values from the 3-4 fields in the form(second tab) and pass these values into first tab(appointment itself: Subject, Location, Start time and Endtime already there by default) values should be posted into the big white text box that is normally used to enter notes about the appointment.
Any help would be greatly appreciated..
That big white are is the Body.
You would access the data in the custom tab in one of 2 ways. If the fields
there are bound to Outlook properties you can access the data either from
the custom property associated with the data control, or you can access it
from the control value.
From the user property, if the property for some text in a textbox is a text
property named Foo you would get the data this way, assuming Item is your
item reference:
Dim sData As String
sData = Item.UserProperties.Item("Foo").Value
If the data is only on a control named textFoo on a custom tab named FooTab
you'd use this:
sData =
Item.GetInspector.ModifiedFormPages.Item("FooTab").Controls.Item("textFoo").Value
You might want to go to www.outlookcode.com and review the material in the
forms sections there to get a handle on the basics of Outlook custom forms.
"bear" <swin_1234[at]yahoo[dot]com> wrote in message
news:uuS6nhfpKHA.5308@TK2MSFTNGP05.phx.gbl...
> appointment in the calendar. Custom form is a second tab. How would one
> Any help would be greatly appreciated.. Submitted using
> https://forums.slipstick.com
K Passing a form field as a parameter from Outlook Using Outlook 12
N Passing Attachments between forms? Outlook VBA and Custom Forms 2
K TextBox on Custom Form Page :: Passing value from sender to the recipient Outlook VBA and Custom Forms 1
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 6
A Add attachments to appointment based on field values Outlook VBA and Custom Forms 0
Diane Poremsky Could not complete the operation. One or more parameter values are not valid. Using Outlook 0
T What code to use to move the custom field values to message body when sending e-mail ? Outlook VBA and Custom Forms 8
N How to retrieve user defined fields values to bcm form. Using Outlook 2
D Multiple values for a field (like categories) Outlook VBA and Custom Forms 1
M Make 2 independent Subs use shared Data Values Using Outlook 3
S Populate textbox values from one form to another form. Using Outlook 0
M Default values for contacts Using Outlook 8
W Linking dropdown values Outlook VBA and Custom Forms 1
M Assigning Values to Contact UserProperties Outlook VBA and Custom Forms 1
J User defined fields with pre-defined values Outlook VBA and Custom Forms 3
J Getting values of custom categories set on Calendar folder Outlook VBA and Custom Forms 2
H Error in values when exporting report to Excel BCM (Business Contact Manager) 1
C Boolean values for Checkbox fields Outlook VBA and Custom Forms 1
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
S Adding Custom Forms Outlook VBA and Custom Forms 4
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
