Help - VB Macro no longer work
  • Thread starter Thread starter mobamoba
mobamoba
I use Outlook 2007 on a single computer (i.e. not Exchange) and have
been using a VB macro for years without a problem. I rebooted today,
restarted Outlook and the macro is no longer working. Nothing in my
setup has changed at all. When I go to the VB Editor, the error I'm
getting is "Object not found." Considering I've changed absolutely
nothing, what, suddenly, isn't being found? I've posted the code
below - it's really a very simplistic macro designed to move email and
meeting requests from my inbox to a folder called Saved Mail. Thanks
in advance for any help because this problem is making me nuts!
Sub MoveMessage()
Dim onsMapi As Outlook.NameSpace
Dim oexpSource As Outlook.Explorer
Dim objItem As Object
Dim omapiDestination As Outlook.MAPIFolder
Dim lCount As Long
' Find the destination Folder 'Saved Mail'
Set onsMapi = Application.GetNamespace("MAPI")
Set omapiDestination = onsMapi.Folders.GetFirst.Folders("Saved
Mail")
' Get the current explorer
Set oexpSource = Application.ActiveExplorer
' Check each selection
For Each objItem In oexpSource.Selection
If TypeOf objItem Is Outlook.MailItem Or TypeOf objItem Is
Outlook.MeetingItem Then
' Move selection
objItem.Move omapiDestination
' Clean up
Set omapiDestination = Nothing
Set oexpSource = Nothing
Set onsMapi = Nothing
Set objItem = Nothing
At which row do you get the error?
Best regards
Michael Bauer
Am Tue, 23 Feb 2010 10:14:18 -0800 (PST) schrieb mobamoba:
> Sub MoveMessage()
> Dim lCount As Long
> Mail")
> ' Move selection
> End If
> Next
> ' Clean up
> End Sub
The line that references the "Saved Mail" folder is the one that's
screwing up:
Set omapiDestination = onsMapi.Folders.GetFirst.Folders("Saved Mail")
Basically, it can't find that folder even though it exists.
I created a new Saved Mail folder as a subfolder of the Inbox and was
able to get it to work using this:
Dim myInbox As Outlook.MAPIFolder
Set myInbox = onsMapi.GetDefaultFolder(olFolderInbox)
Set omapiDestination = myInbox.Folders("Saved Mail")
However, that wasn't really a solution. I don't want a subfolder to
my Inbox; I want Saved Mail as its own folder - and I can't figure out
how to make the macro find it. Any thoughts? Thanks!
On Feb 24, 3:13 am, "Michael Bauer " <m...@mvps.org
> > Best regards
> Michael Bauer
> <http://www.vboffice.net/product.html?pub=6〈=en
> > Sub MoveMessage()
> > Dim lCount As Long
> > Mail")
> > ' Move selection
> > End If
> > Next
> > ' Clean up
> > End Sub
The error is quite clear: the folder doesn't exist.
Check what GetFirst returns, and see if that's really what you expect it to
be.
Best regards
Michael Bauer
Am Wed, 24 Feb 2010 12:52:55 -0800 (PST) schrieb mobamoba:
> screwing up:
>> > > Best regards
> > Michael Bauer
> >> Sub MoveMessage()
> >> Dim lCount As Long
> >> Mail")
> >> ' Move selection
> >> End If
> >> Next
> >> ' Clean up
> >> End Sub
The folder exists. I'm staring at it. I'm a VB beginner - how do I
find out what GetFirst is returning?
On Feb 25, 4:23 am, "Michael Bauer " <m...@mvps.org
> be.
> > Best regards
> Michael Bauer
> > screwing up:
> >> > >> Best regards
> >> Michael Bauer
> >> <http://www.vboffice.net/product.html?pub=6〈=en>
> >>> setup has changed at all. When I go to the VB Editor, the errorI'm
> >>> Sub MoveMessage()
> >>> Dim lCount As Long
> >>> Mail")
> >>> If TypeOf objItem Is Outlook.MailItem Or TypeOf objItemIs
> >>> ' Move selection
> >>> End If
> >>> Next
> >>> ' Clean up
> >>> End Sub
Use more variables, then you can work with the properties of an object. For
instance:
Dim F as MapiFolder
Set F=onsMapi.Folders.GetFirst
Msgbox F.FolderPath
Best regards
Michael Bauer
Am Thu, 25 Feb 2010 07:37:20 -0800 (PST) schrieb mobamoba:
to
> > be.
>> > > Best regards
> > Michael Bauer
> >> screwing up:
> >>> > >>> Best regards
> >>> Michael Bauer
> >>>> Sub MoveMessage()
> >>>> Dim lCount As Long
> >>>> Mail")
> >>>> ' Move selection
> >>>> End If
> >>>> Next
> >>>> ' Clean up
> >>>> End Sub
A newb outlook macro help Outlook VBA and Custom Forms 1
E Help with macro to answer and delete calendar requests? Outlook VBA and Custom Forms 5
A Help creating macro for conditional formatting settings Using Outlook 8
S Help macro Outlook VBA and Custom Forms 1
C Help with a Macro to move emails to a different PST data file Using Outlook 4
F Help with Outlook 2007 Macro Please! Using Outlook 4
S Outlook macro help Using Outlook 10
P Please Help me Create a Macro ! Using Outlook 2
D Help with simple macro - looping though all emails in my inbox Using Outlook 3
S Macro help Using Outlook 4
S Outlook 2003: Help with setting up a macro to reply to selected emails Using Outlook 2
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
L Help for writing an Outlook 2007 macro Outlook VBA and Custom Forms 7
V Outlook macro help please Outlook VBA and Custom Forms 23
