Listing Calendar entries
  • Thread starter Thread starter Barb Reinhardt
Barb Reinhardt
I am not at all familiar with the outlook object model, but am interested in
listing out the calendar entries in my calendar that are full day events.
I'd like to determine if I have them set for Busy or Free or something else?
Can someone direct me to some sample code to do this? FWIW, I'm quite
familiar with the Excel object model and do a good bit of programming there.
Barb Reinhardt
you can see the object model by using the object browser (f2), switch from
<All Libraries> to Outlook.
The GetDefaultFolder function can return the default calendar folder.
Iterate its Items collection, which contains AppointmentItem objects for a
calendar. For instance, read each object's BusyStatus property to see which
one is Busy or Free. You can see all of the available properties in the
object browser by selecting the AppointmentItem in the left pane.
Best regards
Michael Bauer
Am Fri, 12 Feb 2010 05:27:01 -0800 schrieb Barb Reinhardt:
in
else?
there.
> Barb Reinhardt
I now have another related question. I have access to the calendar for
another "email" address (it's actually a group calendar, but it's tied to an
email) and I want to list out the items for that calendar. How do I identify
it as an outlook folder.
Barb Reinhardt
> > Best regards
> Michael Bauer
> in
> else?
> there.
> > Barb Reinhardt
V Folders listing Using Outlook 2
G New email account not appearing on mail folder listing Using Outlook 3
T Using Exchange, the calendar cannot be synchronized. Using Outlook 3
G Forms error on iCloud calendar Using Outlook 18
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
V Unchecking my calendar and leaving shared one visible Outlook VBA and Custom Forms 1
M New Calendar Appointments: Conditionally turn off reminder and show time as free Using Outlook 14
J Cannot edit a calendar event received as an invitation Using Outlook 2
e_a_g_l_e_p_i Question about calendar Using Outlook 5
icacream Outlook 2021 - Google calendar in the peek Using Outlook 0
Fozzie Bear Shared Calendar For Scheduled Tasks Using Outlook.com accounts in Outlook 3
