x-header insertion issue
  • Thread starter Thread starter Microsoft
Microsoft
Hi Ken,
I tried to implement the following code in the ThisAddIn_Startup method on
application startup. The code seems to be working fine and no exception is
thrown on the run time. However, when I go back into the inbox and right
click on option, I couldn't find the 'x-testheader' in the header section. I
have tried out all the possible solutions that I can think of but still no
luck to make it work. Can you please give me some direction on what may went
wrong with the following code? thanks in advance.
foreach (Outlook.MAPIFolder folder in this.Application.Session.Folders)
Outlook.MAPIFolder inbox = folder.Folders["Inbox"];
foreach (object o in inbox.Items)
Outlook.MailItem mailItem = o as Outlook.MailItem;
if (mailItem != null)
// Adding x-header
string xHeaderTag =
"http://schemas.microsoft.com/mapi/string/{00020386-0000-0000-C000-000000000046}/x-testheader";
mailItem.PropertyAccessor.SetProperty(xHeaderTag,
mailItem.EntryID.ToString()); // set entry id value
mailItem.Save();
Cheers,
Kyle
An x-header is created from that MAPI named property only when the item is
sent out. The x-header creation is done after the item leaves Outlook and
goes through the message transport.
So you will never see that x-header in a saved item or even your copy of the
sent item in Sent Items. It will be there only in the received email, and
only then if the email was sent to a recipient outside of an Exchange
organization.
If an email is sent internally within an Exchange organization no x-header
is created because the PR_TRANSPORT_MESSAGE_HEADERS property is never
created. It's also never created on saved items or your copy of a sent item.
"Microsoft" <hkyl_xtra@hotmail.com> wrote in message
news:eMsnq6dsJHA.5912@TK2MSFTNGP02.phx.gbl...
> Hi Ken,
> I have tried out all the possible solutions that I can think of but still
> no luck to make it work. Can you please give me some direction on what may
> went wrong with the following code? thanks in advance.
> // Adding x-header
> string xHeaderTag =
> mailItem.Save();
> Cheers,
> Kyle
Thanks Ken.
Kyle and I want to store a bit of information in the original email so that
when someone replies to it we can programmatically read the information from
the original email now stored in the reply email and take a certain action.
We had thought that X-Headers be able to be used to carry over this
information but as you described below that isn't appropriate.
The next thought I had was to append a bit of text to the body of the
original email so that's carried over to the reply email's body but the
danger there is that the user may inadvertently delete it when composing the
reply.
The next thought was to follow the idea on Sue Mosher's posting thread at
http://www.outlookcode.com/threads.aspx?forumid=5&messageid=24242, in
particular:
"28-Sep-2007 06:31
Very cool indeed! Interesting idea using <input type="hidden">. Have you
seen any problem getting Outlook 2007 to include that tag in the reply,
given that it's one of the ignored elements per
http://msdn2.microsoft.com/en-us/library/aa338201.aspx ? "
But instead of <input type="hidden"> use an HTML property such as Class to
store the bit of information since we are using OL2007 and according to the
post <input type="hidden"> is ignored.
However the questions now remain:
a) What if the incoming email is simply a plain-text email? Can we add a
"Class" HTML attribute for our purposes only, even though it is not an HTML
or rich-text email?
b) What if the reply email being composed is set to plain text or Rich-Text?
Will there be any way of intercepting Outlook's conversion of a normal HTML
email or a) to plain text so we can get our little piece of information?
Basically all of this is to try and make a fast way of identifying the
original email replied to. I know there has been some posts on using the
conversation index attribute and using advanced search to find the original
using that but I seem to recall that wasn't bullet-proof. I think there were
some situations (such as moving emails to different folders?, Exchange
scenarios?) where it wouldn't work. If I am wrong on that please let me
know.
TIA
The HTML idea would only work under controlled conditions. For example, if
someone were to have the setting for read all emails in plain text enabled
that would be one failure point.
I don't really see the problem, unless I'm missing something.
If you add the named MAPI property that becomes an x-header when the email
is sent over the Internet you can check for that. If the email stays within
an Exchange organization and there is no PR_TRANSPORT_MESSAGE_HEADER
property on the item just look for the named MAPI property. One or the other
should be there, so just fork your logic based on checking for both.
"Mark B" <none123@none.com> wrote in message
news:eVZtdJqsJHA.2148@TK2MSFTNGP06.phx.gbl...
> Thanks Ken.
> that when someone replies to it we can programmatically read the
> information from the original email now stored in the reply email and take
> a certain action.
> the reply.
> particular:
> "28-Sep-2007 06:31
> the post <input type="hidden"> is ignored.
> HTML or rich-text email?
> Rich-Text? Will there be any way of intercepting Outlook's conversion of a
> normal HTML email or a) to plain text so we can get our little piece of
> information?
> original using that but I seem to recall that wasn't bullet-proof. I think
> there were some situations (such as moving emails to different folders?,
> Exchange scenarios?) where it wouldn't work. If I am wrong on that please
> let me know.
> TIA
So when a user hits the reply button is the MAPI property of the original
email carried over into the new email so that when the user finally hits the
Send button on the new email we can interpret which email they are replying
to?
We only need to ascertain all this within the Outlook client itself on the
desktop -- we don't need it to be included after it leaves via the Send
event.
In summary -- an email comes in, we want to add a property with a specific
identifier and that gets stored within the email. Then later when the user
replies to that stored email, the new email has a new property to store the
original email's property value. Then when they eventually click Send we
perform our action if certain criteria based on the property are met.
news:eiYFg3ssJHA.4324@TK2MSFTNGP05.phx.gbl...
> within an Exchange organization and there is no
> PR_TRANSPORT_MESSAGE_HEADER property on the item just look for the named
> MAPI property. One or the other should be there, so just fork your logic
> > Thanks Ken.
> > the reply.
> > particular:
>> "28-Sep-2007 06:31
> > to store the bit of information since we are using OL2007 and according
> > to the post <input type="hidden"> is ignored.
> > a normal HTML email or a) to plain text so we can get our little piece of
> > information?
> > think there were some situations (such as moving emails to different
> > folders?, Exchange scenarios?) where it wouldn't work. If I am wrong on
> > that please let me know.
>> TIA
No, the MAPI named property isn't carried over. But neither would the
Internet headers be carried over, so the design is flawed if it counts on
either property being there in a reply.
In an addin you can handle the Reply() event on a selected item or items,
and by handling the Reply() event on an opened item you are notified about
by the NewInspector() event.
Then you can add whatever MAPI properties you want to those newly opened
Reply items.
ConversationIndex and ConversationTopic are used to link an original item
with a reply or replies. Each item in the conversation has the same
ConversationTopic. ConversationIndex has a new date/time structure appended
to it for each new item in the conversation. So you can look for items with
that ConversationTopic to find the conversation, and evaluate the
ConversationIndex property to see which has a value there that's one entry
shorter than the current item.
news:ugJhOpwsJHA.1492@TK2MSFTNGP03.phx.gbl...
> the Send button on the new email we can interpret which email they are
> replying to?
> event.
> the original email's property value. Then when they eventually click Send
> we perform our action if certain criteria based on the property are met.
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
A Check for words in subject header before sending email Outlook VBA and Custom Forms 4
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
C Outlook Attachment List in Reply Header Using Outlook 3
J Identifying Portable Devices in Outlook Header Using Outlook 3
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
oliv- Get to: from internet Header Outlook VBA and Custom Forms 2
O No Internet Header Properties Using Outlook 2
C How to copy same text header to multiple emails with custom text column Using Outlook 10
R Coming from Thunderbird: "Always prefer display name over message header" Using Outlook 1
A change the "no date" header in todo bar Using Outlook 2
G Creating an Outlook Rule using Internet Header time Using Outlook 1
T Column Header Keyboard Shortcut Available? Using Outlook 5
I How to add image header to email Using Outlook 2
E Outllook 2010 Header Image Using Outlook 3
B Need help adding an image next to the Month Name in the header. Using Outlook 1
P Email Header/People pane/contact card - GAL photo vs. contact photo Using Outlook 7
C Custom Form that allows a single SMTP header to be parsed to Field Chooser? Using Outlook 4
M IMAP header/content mismatch! Using Outlook 4
R Header not printing in Outlook 2010 Using Outlook 3
J Header information missing in one account only Using Outlook 10
T Header instead of just a signature for a disclaimer Using Outlook 1
I Message-ID Header Exchange Server Administration 5
P How do i add the date to subject header of incoming mail? Outlook VBA and Custom Forms 13
T Add-in problem: Process All Marked Header doesn't display email bodies Outlook VBA and Custom Forms 5
E phone numbers & addresses header disappear (customized contact) Outlook VBA and Custom Forms 7
S Xref type property in an email header? Outlook VBA and Custom Forms 6
M forward with header gufff etc Outlook VBA and Custom Forms 2
T Is it possible to save email body without header? Outlook VBA and Custom Forms 6
A Access Outlook's Page Header and Footer Outlook VBA and Custom Forms 3
A How to get mail header Outlook VBA and Custom Forms 7
P SBS2008 / Exchange with POP3 Connector / Invalid Header Fields -problem Exchange Server Administration 20
U Export of Message Header / Unique ID to Excel Sheet When email is Outlook VBA and Custom Forms 1
Harald Olsen Automated insertion of address in address line Using Outlook 1
C Solving the "indexing never finishes" issue Using Outlook 8
Z Hotmail account deleted from outlook and issue with account not exist Using Outlook 0
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
