obfuscator problem
  • Thread starter Thread starter Jason
Jason
Can anyone recommend a obfuscator?
We tried Xenocode postbuild but got an error: "This assembly is not strong
name signed." Looks like the message came out of the RunCaspolCommand method
in the CaspolSecurityPolicyCreator.cs of the SetSecurity project.
Can Dotfuscator handle addin and the security challenge?
Any time you obfuscate you must delay sign your assembly and actually sign
it with that SNK or PFX after the obfuscation. Otherwise the
signature/strong naming is also obfuscated along with your code.
"Jason" <a@a.com> wrote in message
news:OmOO8w7tJHA.5452@TK2MSFTNGP02.phx.gbl...
> method in the CaspolSecurityPolicyCreator.cs of the SetSecurity project.
Same problem: xxx.dll does not represent a strongly named assembly
Here is what we did:
1. checked "Delay Sign only" while kept "Sign the assembly" check
2. built, got UnsignedAddin.dll
3. ran Outlook, add-in cannot load
4. manualy sign from commoand line OK: ran sn -R unsignedAddin.dll
keyfile.pfx
5. ran Outlook, addin loaded OK.
6. built again
7. obfuscate the UnsignedAddin.dll =>ObfuscatedUnsignedAddin.dll
8. ran sn -R ObfuscatedUnsignedAddin.dll keyfile.pfx
Got error message: obfuscatedUnsignedAddin.dll does not represent a strongly
named assembly
news:u%23uSfKFuJHA.4444@TK2MSFTNGP04.phx.gbl...
> > strong name signed." Looks like the message came out of the
> > RunCaspolCommand method in the CaspolSecurityPolicyCreator.cs of the
I chekced the article "Giving a .NET Assembly a Strong Name" at
http://www.codeguru.com/columns/experts/print.php/c4643. My procedure was
right.
I then used Dotfuscator Community Edition (not support Office addin) against
a C# console exe, following the same procedure. It worked. Look like
Xenocode postbuild broke the strong name.
What obfuscator do your guys use? How much $?
news:OgRkSYLuJHA.1304@TK2MSFTNGP05.phx.gbl...
> keyfile.pfx
> 6. built again
> " - " <kenslovak@mvps.org> wrote in message
> > sign it with that SNK or PFX after the obfuscation. Otherwise the
I rarely obfuscate any of my code, usually I just hand it over to the
customer and they take care of that since they'll be using their own
certificate to sign the code and not mine. On the rare occasions I've
obfuscated my code I've used the full edition of Dotfuscator.
That article looks right, one thing to try would be if you try using an SNK
file instead of your PFX and using that in your post-obfuscation signing
call.
news:%23z$708LuJHA.1240@TK2MSFTNGP02.phx.gbl...
> right.
> against a C# console exe, following the same procedure. It worked. Look
> like Xenocode postbuild broke the strong name.
> > keyfile.pfx
>> 6. built again
Marc2019 Outlook 2016 Font Problem Using Outlook 4
