Text centered (not left-aligned) in CommandBarPopup
  • Thread starter Thread starter RGllZ28
RGllZ28
I am using a CommandBarPopup in an Office toolbar, and I set the text using
'.Caption(...)'. The problem is that the text is centered by default, instead
of 'left-aligned'.
I have installed the Skype Toolbar in my Outlook, which also has a
CommandBarPopup control, and I see the text left-aligned... So it seems to be
something only in my control.
Why can be that? May it be sth about Office in general?
My code:
------------------------------------------------Dim m_popUpMenu As Office.CommandBarPopup
Set m_popUpMenu = .Add(Type:=msoControlPopup, Temporary:=True, Before:=1)
With m_popUpMenu
> Tag = "Options"
> ToolTipText = "Options"
> Enabled = True
> Width = 120
> Caption = "Options"
------------------------------------------------Thanks in advance
Diego
Answered in another group you posted in. Please do not multipost.
"Diego" <Diego> wrote in message
news:2ECB7952-D2B4-4792-BD8F-FB1062A1D7C7@microsoft.com...
> Hi,
> using
> instead
> of 'left-aligned'.
> be
> My code:
> ------------------------------------------------------------------------------> Dim m_popUpMenu As Office.CommandBarPopup
> With m_popUpMenu
> .Tag = "Options"
> .ToolTipText = "Options"
> .Enabled = True
> .Width = 120
> .Caption = "Options"
> End With
> ------------------------------------------------> Thanks in advance
> Diego
R Text centered in CommandBarPopup (not left-aligned) Outlook VBA and Custom Forms 3
T Replace Text in Email Subject Outlook VBA and Custom Forms 3
M Folder names - rich text Using Outlook 6
E Replying to a plain text e-mail with HTML Using Outlook 2
H Finding text in open email Outlook VBA and Custom Forms 12
D Can't read some emails - text size too small. Using Outlook 2
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 5
J Outlook 365 Emails showing as links and text only Using Outlook 4
J Text icon in Quick Access toolbar ? Using Outlook 2
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
S Unable to extract text from an Outlook email message Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
S Outlook to check for specific text Outlook VBA and Custom Forms 3
B Paste formatted text (bold, underlined and in quotes) Outlook VBA and Custom Forms 1
N Is there an Outlook tool to normalize text for entries that are in ALL CAPS? Using Outlook 2
