Block sender option disappeared?
Hello everyone! I used Outlook 2007 and yesterday I had the option to right click an e-mail in my inbox and click 'block sender' Today when I log in, that option has disappeared from my right click altogether! =( I also noticed that when I click actions -> options, under e-mail junk e-mail options is not there either. If someone could help me out with this I would greatly appreciate it as I have looked just about everywhere for a solution.
Do you have a network administrator or someone who controls the program features of your organization?
If so, you may want to ask them as it is possible they removed the feature for some reason.
Re: Block sender does not work for Outlook 2011
You are missing the add to junk mail command too? Note that it only works with 1 message at a time.
We recommend using junk mail settings on high - adding addresses to the blocked list is less than useful as the spammers just keep changing their addresses.
J How to Block junk/spam domain Using Outlook 0
I Exchange 2019 - MICROSOFT-CORP-MSN-AS-BLOCK Exchange Server Administration 0
L Block email signature image Using Outlook 1
Diane Poremsky Block Macros in Office 2013/2016 Using Outlook 0
A Block user to send emails to specific set of email ids Using Outlook 1
O Block outlook appoinments Using Outlook 1
I How to block time in another calendar without invite? Using Outlook 2
R How to Block from sending mail to public domain. Using Outlook 8
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
Wotme VBA to block senders Outlook VBA and Custom Forms 1
A 5.7.1 Recipient not authorized, your IP has been found on a block list Using Outlook 1
S Block read receipt when outlook is configured to Exchange server Using Outlook 0
M Change font of from/to/subject block Using Outlook 1
M block emails with specific subjects BCM (Business Contact Manager) 1
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
Q Otlk 2007 does not block when in "always prompt for..." mode Outlook VBA and Custom Forms 2
A Opening a link from a specific sender automatically Outlook VBA and Custom Forms 4
L Checking Sender Email Address for trusted domain from list on intranet Outlook VBA and Custom Forms 4
R Capture Sender's Display name and Address Outlook VBA and Custom Forms 3
J Outlook 2016 How tell Outlook not to trust sender? Using Outlook 1
M Screen Scrape Sender IP Address Outlook VBA and Custom Forms 6
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
D Moving Emails Based on Recipient/Sender Outlook VBA and Custom Forms 4
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
