Max size reached for archive folders
minnowlips
Recently installed MS Office 2010 Business edition to replace/update Office XP Pro 2000. Now I am getting the following error messages. I wish to keep all of my emails in the folders (don't want to delete any of these emails) here are the error messages:---
Error while archiving folder "Inbox" in store "Personal Folders". The Outlook data file C:\Documents and Settings\All Users\Documents\Outlook Archive Nov 08\archive.pst has reached the maximum size. To reduce the amount of data in this file, permanently delete some items that you no longer need. You could also consider using the new Outlook data file (.pst) introduced with Outlook 2003 that provides greater capacity for storing items and folders.
Error while archiving folder "Sent Items" in store "Personal Folders". The Outlook data file C:\Documents and Settings\All Users\Documents\Outlook Archive Nov 08\archive.pst has reached the maximum size. To reduce the amount of data in this file, permanently delete some items that you no longer need. You could also consider using the new Outlook data file (.pst) introduced with Outlook 2003 that provides greater capacity for storing items and folders.
Error while archiving folder "Calendar" in store "Personal Folders". The Outlook data file C:\Documents and Settings\All Users\Documents\Outlook Archive Nov 08\archive.pst has reached the maximum size. To reduce the amount of data in this file, permanently delete some items that you no longer need. You could also consider using the new Outlook data file (.pst) introduced with Outlook 2003 that provides greater capacity for storing items and folders.
The error suggest using the newer (.pst) file, I presume I am using the newer (.pst) that came with 2010 purchase. Not sure what my issue is or how to solve. I installed the newer edition without removing the older version, is this my issue and why I still get reference to the older (.pst)? Should I uninstall all portions of Office 2010 ( and office XP) (except data) and reinstall office 2010.
Help! Minnowlips
When you ugraded and kept the same profile or use the old pst files in a new profile, Outlook uses the old pst - it doesn't convert the pst files to the new format. See Ansi to Unicode psts for options.
B Upgrade 2003 to 2010 and max pst file size of 2GB Using Outlook 2
P Microsoft.Data.Odbc.OdbcCommand CommandText MAX length. Outlook VBA and Custom Forms 1
D Max. length of MSO MailItem.EntryID Outlook VBA and Custom Forms 6
F Font Size Using Outlook 3
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
kburrows "New" Outlook Desktop App Mailbox Size Using Outlook 4
D Can't read some emails - text size too small. Using Outlook 2
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
J images on note field display fraction of size Using Outlook 5
e_a_g_l_e_p_i Adjusting font size in folders Using Outlook 1
A Outlook Userform Size Outlook VBA and Custom Forms 2
D Outlook Message Window Changes Size and Position Using Outlook 1
M Mailbox Size Outlook.com or Outlook 2011 Using Outlook 1
Rupert Dragwater Can't change font size Using Outlook 5
T "From" field font size in table list of emails Using Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error Using Outlook 0
Diane Poremsky Changing the Message Size in Exchange Server Using Outlook 0
K Error: Paper Size Invalid Using Outlook 0
M Why delivery receipt size is same than sent email size or even larger? Using Outlook 1
J Increase font size of message body Using Outlook 5
C What exactly happens when you reach the DB size limit? BCM (Business Contact Manager) 5
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
T OST vs PST file size Using Outlook 2
C contact photo size Using Outlook 2
J Font size changed in new mail messages Using Outlook 5
Diane Poremsky Check Message Size Before Sending Using Outlook 0
oliv- Reduce the size of picture attachments: programmatically Outlook VBA and Custom Forms 3
L what is safe size for pst of Outlook 2013 via Office 365 exchange? Using Outlook 1
R PST Size Alert Using Outlook 4
D Outlook 2013 : controlling message size in Windows 8.1 Using Outlook 3
H Outlook 2013 size issue Using Outlook 1
B Outlook 2013 IMAP folder showing 0KB file size Using Outlook 10
O How to increase Font size in Outlook 2013 Using Outlook 1
R Outlook 2007 to 2013 PST still has the 07 size limit not bigger 13 limit Using Outlook 3
chupacabra Enormous size of IMAP .pst file Using Outlook 6
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
B Outlook 2000 Rule to Move txt msg Not Working if size >24KB Using Outlook 3
R IMAP emails size is 0KB Using Outlook 3
