Inbox names appear greyed out
steadyonabix
I'm finding it very difficult to see the names against my inboxes in Outlook 2010.
I found an option under the General tab to change the color scheme to blue, silver or black. In all of them the name written against the side of each inbox seems to be greyed out. I have to take my glasses off and squint at the screen in order to make out which is which.
Is there any way to make these names a more sensible black like normal text?
Brad
Unfortunately, that is a big problem with Outlook 2010. The only advice I have is to change the font size for the folders. It makes it a little easier to see the names. View > Navigation pane > Options > Font.
Thanks Diane
That helps a lot.
You would think in this age of disability awareness someone would have spotted this prior to rolling it out. :confused:
Beta testers complained - Im not sure why they didn't use a darker grey or black following the complaints as it's not a difficult fix to implement. (Letting users pick the color is more difficult to do.)
Did you change fonts or just the size? I switched one computer to 10 pt to test it when someone complained and after a couple of days, had to change it on my other computers. It never bothered me before that. <g>
T POP Sent Folder Synchronization Issue & Inbox Email Date Display Disorder Using Outlook 2
J Outlook inbox question Using Outlook 4
F Outlook 2021 Inbox delete icon missing Using Outlook 5
HarvMan Outlook 365 Inbox Font Using Outlook 8
M Start Outlook 365 at unified inbox Using Outlook 2
F Inbox moves on taskbar Using Outlook 1
F Outlook 365 Group INBOX by date but not by date and time Using Outlook 1
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
S Format Inbox Using Outlook 0
P Emails assigned with a certain category (within a shared inbox) to be copied to a specific folder. Outlook VBA and Custom Forms 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
