Template format not preserved
parekhharsh_j
I have migrated from outlook 2003 to 2010. I had bunch of templates created in outlook 2003 with particular format. When migrated the templates in outlook 2010 does not seem to have preserved their format. Any suggestion? I tried overwriting them in 2010 but no luck.
parekhharsh_j
Thanks for reply. I found the solution Hotfix.
http://support.microsoft.com/kb/2584053
I could create the new template (which I didn't wanted to do) in 2010. I wanted to use the old template created in 2003 version,, which used to get converted to plain text, in 2010 without the hotfix.
T Outlook Template - textbox visible based on combobox selection Using Outlook 1
L Outlook saved template function too limited Using Outlook 2
K Outlook template Using Outlook 1
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
B Switch template with account Outlook VBA and Custom Forms 3
Diane Poremsky Using the Outlook Calendar Template Using Outlook 0
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
A VBA to create meeting from template from a time slot selected in someone's calendar Outlook VBA and Custom Forms 5
Q Editing an outlook. Template file (Otk) Using Outlook 1
P Calendar template Using Outlook 2
M Update field codes when opening Outlook Template Outlook VBA and Custom Forms 2
J Outlook template with environ varaibles Outlook VBA and Custom Forms 0
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
T My Outlook Calendar Template Using Outlook 1
S Ask user to input email template through VBA Outlook VBA and Custom Forms 1
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
B Outlook to Word Template error Using Outlook 4
I how to create appointment using saved template onto public folder shared calendar Using Outlook 3
S Modify account template? BCM (Business Contact Manager) 0
J Adding original email text to outlook message template Outlook VBA and Custom Forms 2
M How to create a document or email template for Opportunities BCM (Business Contact Manager) 0
S Workgroup template file location? Using Outlook 2
D outlook 2010 template accessable to others at work... Using Outlook 1
W Change Template Recipient Automatically - Outlook 2007 Using Outlook 5
W Template to produce calendars with wrapped text & user-defined fields? Using Outlook 1
C Monday Start Monthly Template Using Outlook 0
R How to use an outlook template globally in an organization Using Outlook 1
D Selection of Send-From Account with Template VBA Shortcut Using Outlook 0
L Contact Template Using Outlook 18
R How to design custom template under message/mail form ! Using Outlook 0
H Macro to load an Outlook Template Using Outlook 2
O automate dates in outlook template Using Outlook 1
R Outlook Template: Looking to distribute a VBA Outlook template to other people Using Outlook 1
