Rule problem
lgnfox
Good afternoon!
There is a rule in outlook, it applies when the Email comes from definite address and runs VBA script. There are cases, when this rule doesn’t work correctly. The problem appears then I send some Email simultaneously.
Example:
I send three Email with subjects FW: 1, FW: 2, FW: 3
In Inbox I see them in order FW: 1, FW: 2, FW: 3
But my script gives:
20.01.2012 15:13:29:0974 ***** Process ***** 20.01.2012 15:13:21 Subject FW: 3
20.01.2012 15:13:29:0988 ***** Process ***** 20.01.2012 15:13:18 Subject FW: 2
20.01.2012 15:13:30:0004 ***** Process ***** 20.01.2012 15:13:15 Subject FW: 1
It reverses order Email to FW: 3, FW: 2 FW: 1
Sqript:
Option Explicit
Private Type SYSTEMTIME
wYear As Integer
wMonth As Integer
wDayOfWeek As Integer
wDay As Integer
wHour As Integer
wMinute As Integer
wSecond As Integer
wMilliseconds As Integer
End Type
Private Declare Sub GetSystemTime Lib "kernel32" (lpSystemTime As SYSTEMTIME)
Sub CustomMailMessage_111111111111(Item As Outlook.MailItem)
Dim Path As String
Path = "C:\Post_CB"
Dim fso As Variant
Set fso = CreateObject("Scripting.FileSystemObject")
Dim idFile_Llog As Variant
Set idFile_Llog = fso.OpenTextFile(Path & "\log_in.log", 8, True)
Dim tSystem As SYSTEMTIME
GetSystemTime tSystem
idFile_Llog.writeline (CStr(Now()) & ":" & Format(tSystem.wMilliseconds, "0000") & " ***** Process ***** " & CStr(Item.ReceivedTime) & " Subject " & CStr(Item.Subject))
idFile_Llog.Close
Set fso = Nothing
How can I get another order:
20.01.2012 15:13:29:0974 ***** Process ***** 20.01.2012 15:13:21 Subject FW: 1
20.01.2012 15:13:30:0004 ***** Process ***** 20.01.2012 15:13:15 Subject FW: 3
Outlook is sending them in last in - first out order. You can't force it to change, other than by slowing down the sends. I don't think a rule to hold mail for 1 min would change it, because they are so close in time - but that would also slow down the sends even more. I'm not sure who much time you'd need between messages, in part because it depends on how busy it is with other tasks. If its not real busy, it will start sending these messages as soon as it gets them.
You can watch it by setting outlook offline before sending then go online after opening the outbox. Outlook sends the newest message first (regardless of the sort order in the folder).
Thanks for response.
Unfortunately I can’t influence sending process, because the email comes from other organization. In above post I subscribe example which gives the root of the problem.
I can change receiving settings only.
Are you using cached mode? The order might be correct if you use classic online mode - the code is getting the recieved time, not the sent time. But when outlook syncs, it doesn't always sync oldest to newest - outlook syncs with the server every few seconds and gets new mail until it hits the last downloaded message. Classic mode gets it as it hits the mailbox.
The only problem is that some features (like junk mail filter) won't work in online mode.
Eureka!
Thanks a lot. Your advice solves my problem.
CWM330 This rule has a condition that the server cannot process? Using Outlook 1
A rule name into message - how? Outlook VBA and Custom Forms 5
A manual rule sends mail to wrong folder Using Outlook 5
bhamberg Finding a rouge rule... Using Outlook 6
D How to get this rule to work Using Outlook 0
R Rogue Outlook Rule ? Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
