Contacts constantly reindexing
DavidWS
Lately, my contacts require reindexing on a daily basis. This happens automatically - in other words, yesterday everything was fully indexed and searchable, and today, I see that Outlook started reindexing from scratch and nothing is searchable until the indexing completes. This has been happening regularly as of late.
Any ideas why and how to stop it?
Question for Outlook 2007. Followed the above advice but the problem has not been solved - once again. constant indexing. The only odd feature I have noticed is the creation of a large number of empty Search Folders followed by a number starting with 10. Does this give anyone a clue? Outlook constanlty crashing. Using Vista. Vipre antivirus - makes no difference if I exit
I don't see anything in google re: outlook creating a large # of search folders. Outlook won't be doing it on its own, some addin or other process is creating them.
If you log in to owa, do you see the search folders? You shouldn't unless you are using online mode or they are created on the server.
What is the folder name? or do you mean its blank, with just the number?
Did you look at the folder properties? What criteria do they use? If you open them, what do they find?
Did you try it with outlook in safe mode? Close Outlook and then restart it by holding the ctrl key as you click the icon to restart it.
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 4
F Contacts Missing Using Outlook 3
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
F Outlook's contacts Using Outlook 1
kburrows Outlook Automatically Merging Contacts Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
S Cannot print Contacts Using Outlook 7
L Favorites for People/Contacts? Using Outlook 1
F Moving Contacts to New Profile Using Outlook 0
V Contacts in O365 have changed?? Using Outlook 20
