Contacts Missing
Frank D
Operating system::    windows 11
Outlook version:     2021
Email type or host:    IMAP
Contacts in iCloud are accurate. Several contacts are missing in Outlook, iPhone, and iPad, especially when i tap "To".
Are the calendar and contacts syncing with iCloud? Create a test contact and test appt in one of the devices and in outlook - see if everything syncs. (Use AAAA AAAA as the contact name so it floats to the top.)
If they are not syncing, sign out of the iCloud app then sign back in.
Do you see the iCloud contacts folder when you click To? If not, open Outlook address book, click Tools > options and set the iCloud contacts as default to show first at the bottom. Steps and screenshots are here:
This usually happens when your devices aren’t all pulling from the same contacts source, even though iCloud has the correct list. On your iPhone and iPad, go to Contacts settings and make sure iCloud is set as the default account and syncing is turned on, then refresh or toggle it off/on. In Microsoft Outlook, check that the iCloud contacts folder is selected and not a local or Exchange list, since the “To” field only shows contacts from the active address book.
The iCloud for Windows status-window should show the last time each item-group was updated. If one doesn't look correct, try adding or editing one of those (the usual way). That should jolt-it-into an update/sync of that group.
S Missing Outlook calendar and contacts Using Outlook 0
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
A Contacts missing in imported mails Using Outlook 1
J Missing business contacts! BCM (Business Contact Manager) 4
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
S Missing Contacts Folders Using Outlook 6
T Reinstalled OL2010 now have 3 separate inboxes and contacts missing Using Outlook 2
R Missing contacts and Opportunities in BCM 2010 Shared database BCM (Business Contact Manager) 1
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 3
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
F Outlook's contacts Using Outlook 1
kburrows Outlook Automatically Merging Contacts Using Outlook 2
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
L Applying new form to existing contacts -- MessageClass Outlook VBA and Custom Forms 3
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
S Cannot print Contacts Using Outlook 7
