How to do a scanpst in thin clients???
vishak
HI Guys,
Does anyone have an idea as to how to repair a PST file using scanpst in a thin client? Since the thin client doesnt have a local storage, the scanpst couldnt be located in office12 file. And I am not able to install it on the client as it says some .dll file missing. I tried to fix it from servers end but wasnt successful. Its a 2007 R2 environment and exchange 2007 setup. Thin clients use citrix xenapp to connect to network.
Many Thanks,
Vishak....
I'm surprised you are using pst files in a thin client - most sites use exchange online and block pst files. ASAIK, you can't use them on a thin client - it would need to be installed on the terminal server, but many apps won't work as expected in TS environments.
Do you have a local machine you can use for repairs? Copy the pst locally, scan it then copy it back, replacing the old one.
Hey that could be done!!!!
Its an old setup and will be migrated in sometime. However, the PSTs are stored in a home folder of every individual user on a network drive, creating a profile for everyone and there is no .OST for users. And you are right that many apps that wont work as expected. I am thinking of running a scanpst on the server itself and mapping the users PST file through his home directory. What say?? If this fails, I will try your way!!!
Many thanks,
Vishak...
I'd certainly try it from the server first- it will either work or not work and shouldn't take much time to find out. :)
It worked!! I couldnt scan for the first time since the user had an active session running. I logged him off, scanned the PST from server and mapped it again.
Its up and running. Thanks :)
J Outlook 2021 ScanPST errors (yet again ... sorry): repair button missing Outlook 2021 Using Outlook 7
P errors appear every time I run SCANPST Using Outlook 3
A ScanPST finding errors but no Repair button Using Outlook 2
C scanpst.exe doesn't repair .pst file Using Outlook 1
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
C scanpst.exe will not open Using Outlook 0
makinmyway ScanPST.exe Missing Repair Button Using Outlook 15
G Error when running scanpst.exe Using Outlook 1
Jennifer Murphy ScanPST results discarded? Using Outlook 10
R ScanPST finished, but no repaired folders appeared? Using Outlook 1
S Using Scanpst too often? Using Outlook 2
W scanpst gets freezed Using Outlook 2
H ran scanpst.exe and that fixed most, but cannot access personal folders Using Outlook 1
N Inbox repair tool - scanpst.exe. That file is missing from my computer. Using Outlook 2
B Outlook fails - error says execute scanpst.exe but can't find it Using Outlook 8
norbertlars Exchange 2007 - quota not shown in clients Exchange Server Administration 2
P Newly created IMAP subfolders not showing up on email clients away from computer. Using Outlook 3
blashmet Outlook Signature Distorted in Other Email Clients Using Outlook 9
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
K Read, unread, i'm losing clients! Using Outlook 1
