How change Contacts to using several letters?
vibesguy
In my old Outlook I could type, say, 3 letters and only one contact (or a very small group with those letters in common) would appear. Now, on Outlook 2010, a large # of contacts appear with any fragment of those letters as well as the notes section underneath a Contact. This makes searching basically unusable. Anyone know how to change that setting??
thx!!
C Change Photo Size of Selected Contacts Outlook VBA and Custom Forms 1
C Change default reminder time for contacts Using Outlook 2
G Change length of phone number in contacts Using Outlook 5
S change default contact list in Outlook 2010 to "contacts" rather than "global" Exchange Server Administration 1
S Change Columns of Linked Accounts and Business Contacts BCM (Business Contact Manager) 1
C How do I change the default "Add to Outlook Contacts" Folder Using Outlook 6
W frustrating trying to change email password Using Outlook 5
R Outlook 2021 change view Using Outlook 2
C Mass Change Selected Contact Photos Outlook VBA and Custom Forms 1
D Unable to change AppointmentItem.Start property Outlook VBA and Custom Forms 3
sjmo2 Change subject for new e-mails only. Outlook VBA and Custom Forms 2
Horsepower Contact phone numbers randomly change Using Outlook 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
whizzard Change FROM address based on TO or CC address Outlook VBA and Custom Forms 8
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
S Unable to change Message Class Outlook VBA and Custom Forms 0
C Outlook 365 Can you change the follow up colour? Using Outlook 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
Witzker HowTo Change message Class of contact form Outlook VBA and Custom Forms 0
R How to Change Margins In Google Docs...? Using Outlook 0
D Change senders title Using Outlook 1
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
B Change from Address Outlook VBA and Custom Forms 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
R Folder pane width change Using Outlook 90
