Occasional Mail Failure Notice Issue
testerdahl
I have an interesting issue that I haven't been able to quite lick yet. Specifically, I have one email address (will call it "A") out of the hundreds I use daily that sometimes bounces back to me. What I have noticed is that if I haven't emailed A in a while, the email goes straight through. However, if I email A several times over the span of a few days, the first few emails go through (2-3) and then the latter ones get rejected. The failure notice says, "Sorry, I couldn't find any host by that name." Even though it found that host successfully just one email ago.
I have tried emailing A directly through my webmail option (I use GoDaddy and a POP3 account) and that email consistently goes through fine. No problems like above using Outlook. I have also changed all my outgoing SMTP port settings and emailed A several times using all the available options. The same thing occurs where it seems fixed for a few messages and then it doesn't work.
And I have emailed A using other accounts through my Outlook specifically my POP3 gmail account. Those emails go through correctly yet he is a work client and I want to use my work account not my personal account.
Lastly, I have also contacted GoDaddy directly and of course, I get the "if you have tried all of our port settings and it sends through Webmail, it must be Outlook." When I have contacted Microsoft about Outlook predictably I get "it can't be on our end, it must be through your email host." Basically, neither side is worth a darn.
Has anyone else had an issue like this and/or does anyone have any additional advice?
Tim
It sounds like the problem is with the autocomplete cache - not sure why it works and then stops though. When it fails, try deleting his name from the autocomplete cache - begin typing his name in the to field, select the name when it comes up and press Delete.
Another possibility - it's your antivirus scanner. Some AV software installs an Outlook add-in and intercepts all email that is sent so it can scan it. You could try using safe mode to see if the problem comes up - if so, its more likely caused by an addin.
Good ideas! I hadn't thought about the AV software being an issue, however, that seems really likely. I'll try both and see what happens.
-Tim
T IMAP mail sync is extremely slow Using Outlook 4
S Mail not showing in created folder Using Outlook 10
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
Rupert Dragwater Mail won't show as read Using Outlook 2
O Junk E-mail Options disabled(?) Using Outlook 3
E Replying to a plain text e-mail with HTML Using Outlook 2
P Limited Support for 3rd Party Mail in new Outlook? Using Outlook 1
T Exchange Server - Mail Delay Stamping Exchange Server Administration 0
L Error when exporting Sent Mail to Excel Outlook VBA and Custom Forms 6
P What is your strategy for dealing with SPAM and Junk Mail? Using Outlook 1
A manual rule sends mail to wrong folder Using Outlook 5
Cathy Rhone Mail merge error message Using Outlook 1
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
