How to format text within appointment/meeting body?
RKDuke
Outlook 2013 32 bit
Using Outlook 2013 and can't figure this out. In previous Outlook versions when I was composing a meeting invite and typing text in the body the toolbar/ribbon would have formatting buttons (bullets, fonts, etc.). In Outlook 2013 this isn't the case. I went to customize the ribbon and added the Format Text tab unto the ribbon. It did this but all the icons are grayed out and inactive. What's going on?
RKDuke
Outlook 2013 32 bit
Are you using plain text formatting in the message? The formatting bar is only available when you use HTML (or RTF, which you shouldn't use).
I'd like to use HTML for my formatting Diane. Your note makes me think that I inadvertently have plan text selected for Calendar events. In my Options I definitely have HTML selected for Mail but can't find where to set the formatting option for Calendar events. How do I do this?
Where is the calendar? Normally, the calendar events aren't plain text - but I know they are in Outlook.com folders and iCloud. This is a limitation of server (and devices) they sync with.
RKDuke
Outlook 2013 32 bit
Yes, the calendar is in iCloud. I thought the most recent version of iCloud addressed this problem? No?
Nope, iCloud is still plain text with very limited options.
M Email Format getting changed to Plain Text Using Outlook 1
F Text Format Change - Bulk Edit Contact Notes Using Outlook 2
S write and format a piece of text in the body using vba Outlook VBA and Custom Forms 7
Y Setting Text Box to HTML or Rich Text Format Outlook VBA and Custom Forms 3
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
S Combination Field (Date Format) Outlook VBA and Custom Forms 0
L Format Lost between Tasks and To Do Using Outlook 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
S Format Inbox Using Outlook 0
P Short Date Format when typing in a task Using Outlook 2
L Time format in Outlook calendar and emails Using Outlook 0
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
Witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
M font format discrepancies with Quick Parts Using Outlook 1
S Email Format With Embedded Images and Tables Change Using Outlook 2
G How to filter by the format of an email address Using Outlook 6
R Lost PST files after format Using Outlook 6
fitzgerald Lost PST files after format - how to recover deleted files? Using Outlook 3
Dr. Demento Outlook output to array -> Excel & re-format Using Outlook 2
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
skylark53 Loss of default format on deleting signature Using Outlook 5
O Setting default format for composing/replying to emails Using Outlook 3
divan VbaProject: Changing email format Using Outlook 15
O VBA to change message format and add formatted signature Outlook VBA and Custom Forms 1
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
M Macro to Format certain words in email message Outlook VBA and Custom Forms 5
J Format change when dragging from email to Task Using Outlook 1
P Outlook 2013 Phone Number Format Using Outlook 0
L Excel table format lost in Outlook Using Outlook 6
H Disaster. Management wants to change email format. Exchange Server Administration 9
S Change answer format Using Outlook 1
R printing custom number of calendar days in weekly view format Using Outlook 1
D outlook 2010 table format lost on send Using Outlook 1
M Save embedded image in native format Using Outlook 6
P Template format not preserved Using Outlook 3
R NUMBER Format Using Outlook 0
M Mail in HTML format can't be sent if url or number is in the body Outlook 2010 Using Outlook 2
