Events in Calendar not Bold
hktrooper
Outlook 2013 64 bit
I have several systems accessing iCloud, my iphone, laptop (dell, win7 64bit) and my laptop (win7 64bit).
I have noticed that on my iphone and pc my icloud calendar shows events on dates in bold which is great. However, on my laptop although the events are in the calendar the dates are not bold.
Is there a simple fix, have I turned something off?
Many thanks
Martyn
Outlook 2013 on both computers? The navigation calendars on the left should show bold for any date with a busy appt if the calendar is selected. The Peek calendar doesn't use bold formatting.
Try resetting the view.
F Show events in Monthly Calendar Using Outlook 3
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
O Carriage Return - Line Feeds - exporting Calendar events Using Outlook 0
G Outlook VBA and Google Calendar ("Events") Outlook VBA and Custom Forms 1
P Outlook 2013 Calendar events not appear on Outlook.com Calendar Using Outlook.com accounts in Outlook 6
V iCloud not syncing categorized calendar events Using Outlook 7
W All Events Disappear from Calendar Display Using Outlook 30
J Calendar view for future events only? Using Outlook 3
microsvc Populating everyone's calendar with campus events Exchange Server Administration 1
Dave Godbey Sending Categories on Calendar Events Using Outlook 1
E Outlook 2013 , iCloud linked calendar, events one hour ahead for about a month Using Outlook 5
B Series of calendar events? Or Tasks? Using Outlook 1
P Printing calendar (work week) with numerous (i.e. >7) all day events... Using Outlook 3
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Using Outlook 2
O pasting text in body of calendar events Using Outlook 5
S Copy Events to Second Calendar or Sync Only "Busy" Events Using Outlook 5
K Private Calendar events Using Outlook 3
G How to insert a json array into a calendar events Outlook VBA and Custom Forms 1
J Get Dates of Recurring Events in Shared Appointment Calendar Outlook VBA and Custom Forms 4
M How do I find Calendar events that have been put off with Snooze? Using Outlook 2
R How do I keep old calendar events from disappearing? BCM (Business Contact Manager) 2
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
O After filtering, how to display all events on that day? Using Outlook 4
A Outlook Reminders not populating for certain events Using Outlook 2
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
P Outlook custom fields "events" Using Outlook 0
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
T Categorizing different colors for a series of events Using Outlook 0
oliv- property "is printed" or catching print events Outlook VBA and Custom Forms 2
I Multiple events in single request Using Outlook 6
T Events Not Showing In Outlook Today Using Outlook 3
G Hiding All Day Events Using Outlook 1
C Problem accessing events for folder "username" Server Threw Exception Using Outlook 1
S Syncing Past events from Outlook 2013 to Outlook.com Using Outlook.com accounts in Outlook 6
F Printing all day events only Using Outlook 3
B Timed events created in iPhone auto-change to All Day events in Outlook 2010 Using Outlook 2
S Outlook - Reset the number of day-events Using Outlook 0
D All New Appointments are All Day Events Using Outlook 1
S Full-day events Using Outlook 1
T Changing default reminder time for all day events - additional help needed Using Outlook 1
A Share recurrent events with others Using Outlook 2
