Help Pleeeeease!!
Big_Steve
I run a busy photography business and until recently kept all of my diary event in outlook and had them synchronised to my iPad and iPhone successfully.
When I upgraded (ha!) to iOS 7 things wen awry. First my outlook had a problem synchronising with outlook so they just didn't talk. I took advice from a forum and deleted the iCloud panel and reinstalled it. Next came the nightmare, it deleted my up to date outlook calendar and replaced it with the older iCloud calendar! This means that I have lost all recently mAde appointments.
i thought I'd be able to do a system restore but for some reason the last restore point is very old!
is there anything I can do to get my old calendar back.
Any help or advice would be really appreciated.
I'm not sure what happened to them, but unless they are in a file on your hard drive, they are probably gone.
I'm assuming you only have one iCloud data file at %localappdata% ? Paste that in the address bar of windows explorer and press enter - the iclod folder should have a long code for the name, ending in .aplzod. (Mine is 389CB898-BA69-4512-991A-AC66E7F4C2E2.aplzod) - there are normally 4 folders inside it.
