Custom task form issues!
louisjmaxwell
Hello all.
My brain is numb from staring at Outlook now!
I have created a custom task form that has some custom text and number fields in. I have also created a custom view in Outlook tasks to mirror the extra fields in the custom form.
Owners use a generic task mailbox (where the custom task form is published) to create tasks and assign them to reviewers. The reviewers accept the tasks into their personal task folders where they have also published the custom task form so they can read the custom task tab. They have also setup the custom view in Outlook tasks.
However, I have a slight problem; when I assign the task, I fill out all of the custom fields and assign to a reviewer who receives and accepts the task, can see all of the custom fields values except two of them? The two last fields are showing as 0 to them for some reason?
And when they try to update the fields and return the task back to me the values in these two custom fields in particular, reset to 0 again!?! It's as though the re-assigning process messes up these fields! And odd that it's only two of the 8 or so custom fields?
Is anyone able to advise!?
Many thanks,
Louis
Where is the custom form published? It needs to be in the Organizational Forms Library so everyone can access it. It's also possible the values are not being sent with the form. Assigned tasks use a different form than tasks so the value may not be sent along with it.
P Custom form reverts from task Outlook VBA and Custom Forms 1
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
W Custom Task Form: Scrollbars Do Not Appear On Textbox Using Outlook 4
S Custom Task Form - Reminder Control Outlook VBA and Custom Forms 1
N Custom Task form - security Outlook VBA and Custom Forms 5
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
Brian Outlook List of custom task views missing in OL2013 Using Outlook 2
P accessing custom task pane with Outlook ActiveInspector Using Outlook 1
F Outlook 2010 custom font style duplicates itself every time I save a task Using Outlook 0
T Custom Task Request Deployment Outlook VBA and Custom Forms 5
E After resizing Custom Task Pane "BeforeFolderSwitch" Event handler stopps being called Outlook VBA and Custom Forms 11
S Drag-and-drop to Custom Task Pane Outlook VBA and Custom Forms 2
P Custom Task Cannot be open when assigned. Outlook VBA and Custom Forms 7
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
S Adding Custom Forms Outlook VBA and Custom Forms 4
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
