Custom Task Form: Scrollbars Do Not Appear On Textbox
wreade
Older version
I am using an old version of Outlook (2002) in which I am attempting to create a custom task form. I have two text boxes within this custom task form. Textbox (A) is where a user can enter some information. After a user enters information, they can click a button to add that information to the previous information posted to the task, which is Textbox (B). Unfortunately, the scrollbars for these two textboxes act differently, even though they are basically the same. In Textbox (A), if the text entered goes longer than the height of Textbox (A), a vertical scrollbar appears. In Textbox (B), if the text entered goes longer than the height of Textbox (B), a vertical scrollbar does not apopear.
Any thoughts on why the vertical scrollbar for Textbox (B) wouldn't automatically appear?
I wanted to attach images showing the textboxes displaying and not displaying scrollbars, as well as the advanced properties for each textbox, but the max size for the images that can shared in this forum is too small to make it useful.
Will
Forum Admin
In the properties for the field, is there an option to set the scrollbar? (I'll have to boot up a 2002 system to check and see if i can repro.)
wreade
Older version
In the advanced properties there is a property for scrollbar. I have it set to vertical for both textboxes, but it seems to only work for Textbox (A) not Textbox (B).
without seeing the form, its hard to say why its not working. If you want, you can email it to diane at slipstick and i'll see if i can see why its not working.
(I'm not sure screenshots would make a difference - we really need to see the form - but I will check the forum settings. I thought we had the image stuff fixed. )
wreade
Older version
Where does Outlook store the form I made so that I can send it via email? Is your email address at slipstick.com?
P Custom form reverts from task Outlook VBA and Custom Forms 1
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
L Custom task form issues! Using Outlook 1
S Custom Task Form - Reminder Control Outlook VBA and Custom Forms 1
N Custom Task form - security Outlook VBA and Custom Forms 5
Brian Outlook List of custom task views missing in OL2013 Using Outlook 2
P accessing custom task pane with Outlook ActiveInspector Using Outlook 1
F Outlook 2010 custom font style duplicates itself every time I save a task Using Outlook 0
G Displaying value of task subject field as values from two custom fields Using Outlook 4
T Custom Task Request Deployment Outlook VBA and Custom Forms 5
E After resizing Custom Task Pane "BeforeFolderSwitch" Event handler stopps being called Outlook VBA and Custom Forms 11
S Drag-and-drop to Custom Task Pane Outlook VBA and Custom Forms 2
P Custom Task Cannot be open when assigned. Outlook VBA and Custom Forms 7
S Adding Custom Forms Outlook VBA and Custom Forms 4
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
