Button to Forward and Move
consultant
Outlook 2013 64 bit
I want to add a custom button to Outlook 2013 that when I press it forwards the email to a pre-defined address and changes the sender address (from) to a standard address (as I'm using the button on multiple accounts but it needs to come from the same account), then, moves the message to a predefined folder.
I'd prefer the forwarded message not get saved to my sent items folder (I'm using IMAP)
Thanks in advance for the help!
Quick Steps can handle the Forward part but the messages will be sent from the account that received them. If you want always send from a specific address, you'll need to use a macro.
This should do it for you
Public Sub ForwardUsingOneAccount()
Dim oAccount As Outlook.Account
Dim oMail As Outlook.MailItem
For Each oAccount In Application.Session.Accounts
  If oAccount = "me@domain.com" Then
    Set oMail = Application.ActiveExplorer.Selection(1).Forward
      oMail.SendUsingAccount = oAccount
      oMail.Recipients.Add ("alias@domain.com")
oMail.Display 'or use .send
That is from http://slipstick.com/outlook/email/choose-the-account-to-send-a-reply-from/
Is that code appropriate to associate with a button to run the operation on the current e-mail being viewed? I don't see why if would have to loop through all the accounts? I do use though a macro to give me a unified view of the inbox of multiple accounts. I discovered the built-in Move to OneNote button does not work from that search view but I don't mind having to go into individual account inboxes to move items. Ideally though I could highlight multiple emails within the unified view and use the macro button to forward them (as described) and move them all to a sub-folder of the inbox in one particular account. I think that might be hard and maybe not necessary though. I could live I guess with using the sent folder in each account (or one account if that is how it ends up working) as my archive of the emails I forwarded. Trying to keep this simple.
What about moving the file after to a specified folder instead of the sent folder?
Yes, it will work with a button on the ribbon. The macro assumes the messages arrived on any of your accounts and you want to always send using Account B - so it needs to loop through looking for the correct account.
If you are moving mail to a specific folder, use a Quick Step. You can move sent messages to another folder - you can turn off the option to automatically save sent items and use an after sending rule to save everything in other folders.
Doesn't it make a difference that I want the e-mail to still go to the sent folder, but only go to a specific folder when I use this macro button?
M Forward email as insert from button Outlook VBA and Custom Forms 1
C Outlook 365 What happened to the "Today" button? Using Outlook 13
J Hide/Disable the X button on BrowseForFolder Dialog Using Outlook 4
B Please remind me how I added this message button Outlook VBA and Custom Forms 0
J Outlook 2021 ScanPST errors (yet again ... sorry): repair button missing Outlook 2021 Using Outlook 7
jehan2256 "History" button in Business Contact Manager Using Outlook 1
L "Insert Pictures" Button-Wrong Folder Using Outlook 5
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 5
J "Contact" button in Journal entry Using Outlook 1
Witzker HowTo start a macro with an Button in OL contact form Outlook VBA and Custom Forms 12
N Which Button Was Clicked on the Ribbonbar Menu Outlook VBA and Custom Forms 2
E Can't accept or decline task (no button appears) Using Outlook 2
Witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
A ScanPST finding errors but no Repair button Using Outlook 2
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
S Reminder Dialog Open Button Using Outlook 2
Wayne Dardis Calling Ribbon Button in Outlook 2016 Outlook VBA and Custom Forms 6
E Button to change subject Outlook VBA and Custom Forms 1
S Shortcut/button to a Calendar Group Using Outlook 0
I Creating meeting invite with disabled tentative button Outlook VBA and Custom Forms 5
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
T Unable to 'Upload a file' using popup 'Browse' button Using Outlook 0
makinmyway ScanPST.exe Missing Repair Button Using Outlook 15
K Remove Manage APPS button for users Exchange Server Administration 1
