HYPERLINK "mailto:test@test.com" in form body
Witzker
OS Version(s)
  1. iOS
Outlook 2019 32-bit
Exchange Server 2007
Hallo,
In my user defined form I use a macro to write text in the form body.
The code:
Item.Body = Item.Body & vbCrLf & Date() & " - " & FormatDateTime(Time,4) & ": "
Set objWSHShell = CreateObject("WScript.Shell")
objWSHShell.SendKeys("{TAB 11}")
objWSHShell.SendKeys("^{End}")
objWSHShell.SendKeys("^{backspace}")
It works fine but I noticed that, when I have an email address in the body, it changes from:
eg: test@test.com to: HYPERLINK "mailto:test@test.com" test@test.com
each time the button with the code is pressed
another: HYPERLINK "mailto:test@test.com" is added
are there some settings in outlook?
something wrong with the code?
How can I solve this?
Many thanks for your help.
Regards
WITZKER
Thx for reply
Tried Item.HTMLBody for one and both.
Result: ERROR
Iam using german version:
Das Objekt unterstützt die Eigenschaft oder Objekt nicht
The object dosn't support attribute or objekt
Pls note the code is in the OL form Code
What I learned from other therad there is used vbscipt.
Lookin forward to a solution
Diane! Great idea
As you see I'm already using sendkeys in the code to go to the bottom of the body.
It would be great if you would be so kind and let me have the code to insert the text:
if possible also in red letters?
Regards Witzker
many thanks for your effort.
Is it possible to do this in a VBA macro which is located in a module instead of the code in the user definde form where only VBSkript is available?
can Item.HTMLBody be used in VBA?
If Yes what VBA code would you suggest?
The procedure for using this macro could be
open the contact
and call the macro from the ribbon.
What do you think?
Thanks Witzker
Oh, yes, it will work perfectly in VBA. You'll be able to use HTMLBody, formatting the time could be easier, and you can add color. I might already have something on slipstick that comes close but I have a meeting coming up and can't look for it right now. Give me 3 or 4 hours and if I haven't updated this thread, remind me. :)
Re: HYPERLINK "mailto:test@test.com" in form body
Ok... messy is my middle name :) It could be a little cleaner and neater, but it does the job.
I tweaked the macro at http://www.slipstick.com/developer/word-macro-apply-formatting-outlook-email/ to insert the date at the bottom of the page and move the cursor back to the top.
 Public Sub FormatSelectedText()
    Dim objItem As Object
    Dim objInsp As Outlook.Inspector
   ' Add reference to Word library
    ' in VBA Editor, Tools, References
    Dim objDoc As Word.Document
    Dim objSel As Word.Selection
'Reference the current Outlook item
    Set objItem = Application.ActiveInspector.currentItem
    If Not objItem Is Nothing Then
        If objItem.Class = olMail Then
            Set objInsp = objItem.GetInspector
   'move to end of message
objSel.EndKey Unit:=wdStory
set formatting
       With objSel
       ' Formatting code goes here
            .Font.Color = wdColorBlue
            .Font.Size = 18
            .Font.Bold = True
            .Font.Italic = True
            .Font.Name = "Arial"
'adds a line break
       objSel.Range.InsertParagraphAfter
'inserts date & time in 3/7/2014 12:55 format
         objSel.Range.InsertAfter "Time Stamped at " & Date & Format(Time, " hh:mm")
' another linebreak
'jump back to the top
objSel.HomeKey Unit:=wdStory
   Set objItem = Nothing
    Set objWord = Nothing
    Set objSel = Nothing
    Set objInsp = Nothing
THX GREAT :)
i will adapt the code for a contct form and put it in Module 2
How can I start the macro from a custom botton in the form code
Sub CommandButton1_Click
HOW to start the macro in Module2 ??
I hope you can let me have the code
regards
Witzker
You can use this:
FormatSelectedText
Or add a button to the QAT or ribbon for the macro - file, options, customize ribbon or quick access toolbar. Select Macros from the dropdown and add to the ribbon or QAt.
Thx
I have tried:
FormatSelectedText
in the code of custom form
also tried
run FormatSelectedText
run FormatSelectedText()
Error:
Typenkonflikt "FormatSelectedText"
sorry
where is the problem?
Hope for a solution
According to http://support.microsoft.com/kb/221827/ if the macro is in ThisOutlooksession and you call it using Application.macroname, it may work, but it's not recommended or supported.
- - - Updated - - -
It's not working for me in Outlook 2013.
You can use this:
FormatSelectedText
Thx
is there another way to call a macro from ol form?
toad a field or dropdown with macros?
button wouldbe best
Hope for a solution or woraround
You can add a button to the QAT or to the ribbon. You can't make dropdown buttons, but if you need dropdowns, you can use userforms.
see How to use the VBA editor - down at the bottom is instructions to create buttons on the ribbon.
@your post Diane
in this article at the bottom is the solution to call the vba macro from the button!?:
As an alternative to calling Visual Basic for Applications code from VBScript, you can create a Visual Basic automation server, install it using a Visual Basic Setup program, and then launch the Visual Basic component by using the CreateObject method in VBScript.
Ok - but I do not understand how to do this.
I think to be able to call a VBA Macro (with all possibilities of VBA) from an OL Form with a button gives a lot possibility in realizing custom projects.
So I hope for further help on this topic.
Regards
Witzker
Hi again
for the case there is really no solution to start a VBA macro with the form code I am thinking of a work around to add some buttons into the ribbon and as suggested use a user form in VB for the other macros.
First step would be following task:
I open a contact
than click on phone, to make a telephone call to the contact
Then I have to run the macro that inserts date & time and the person who called the contact in the body. (which is now working fine with your code)
It would be great when I can open the phone dialog at the beginning of the macro which inserts the date & time ....
I tried with sendkeys " STRG+Shift+D" - SendKeys "^+{D}"
I got the phone dialog open where I can start the call, but in in its window all fields are empty - meaning there is no number to call in the box.
So my question is:
If you would be so kind and let me have the code that opens the phone dialog like pressing the phon button in the ribbon of an opened contact.
Many thanks in advance
Regards
Witzker
V Using custom field data in mail body + mailto hyperlink Outlook VBA and Custom Forms 7
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
C No Hyperlink when Sharing an article from the Web Using Outlook 8
V Embedding hyperlink into Word document Using Outlook 2
L Ignore hyperlink from being flagged as false pattern Outlook VBA and Custom Forms 3
N open the hyperlink in Outlook directly instead of browser Using Outlook 1
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
M How to view the URL for a hyperlink? Using Outlook 1
A Add Hyperlink to Task Outlook VBA and Custom Forms 11
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
A Create Macro for hyperlink(email) in message body Outlook VBA and Custom Forms 9
Diane Poremsky Disable the Unsafe Hyperlink Warning when Opening Attachments Using Outlook 0
C Hyperlink to an Outlook search Using Outlook 1
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
E Create a URL hyperlink in an Outlook custom form? Outlook VBA and Custom Forms 2
J Macro generating email using default signature and hyperlink Outlook VBA and Custom Forms 5
Hudas Hyperlink Saved Outlook Email to MS Access Table Using Outlook 4
D Particular Facebook "Hyperlink" Issue In Office 2010 Outlook (32 bit) Using Outlook 5
S email body without "HYPERLINK" ( vba ) Using Outlook 6
M How to create a hyperlink to to an organizational form Using Outlook 5
J Hyperlink VBA Using Outlook 1
P Can't add a custom hyperlink to toolbar in OL 2010 Using Outlook 1
T Desable Hyperlink on email Using Outlook 3
O Hyperlink formatting lost after replacement in outlook Using Outlook 5
O Hyperlink formatting lost after replacement in outlook Using Outlook 0
G Hyperlink Using Outlook 1
P Hyperlink to Access record/Form Outlook VBA and Custom Forms 2
M auto click hyperlink?! Outlook VBA and Custom Forms 1
M Auto click a hyperlink Outlook VBA and Custom Forms 2
R Inserting a hyperlink in the bod of an outlook appt. Outlook VBA and Custom Forms 13
K Add Hyperlink in Email Body by VBA Outlook VBA and Custom Forms 1
G <mailto:user@domain.com<mailto:user@domain.com<mailto:user@domain.com>>> Using Outlook 5
P mailto replication in Outlook Contact Notes Using Outlook 4
R Mailto link inside Outlook 2010 being cached? Using Outlook 1
mrje1 mailto links in browsers don't open up outlook email Using Outlook 2
R Some Mailto items dont work Using Outlook 3
Diane Poremsky Test 2 Using Outlook 0
Y Disable Microsoft Outlook Test Message Using Outlook 4
Diane Poremsky test Using Outlook 2
M Change default "automatically test account settings when Next is clicked" Using Outlook 1
A Outlook 2010 - Want to Have All Email Reply Forward as Rich Test Using Outlook 7
R Test if cursor is in To... field Outlook VBA and Custom Forms 1
H Sending a test email to sender's own account. Outlook VBA and Custom Forms 3
