Can only see emails no later than two weeks old! HELP!
rdunlap
Exchange Server 2010
Hello there. We use Outlook 2010 and Exchange 2010 and I am having an issue with one user. She called yesterday to tell us that she was looking at her inbox and she noticed that she couldn't see any email after two weeks old. This user uses two different computers, one at her desk and then one at the front secretary desk where she sits about 2 days a week.
I then checked to see if she had any filters on, even started outlook.exe /cleanviews, /cleanrules, and /safe and still couldn't see past two weeks. I then checked to see if cache mode was checked and it was not on either computer. Checked her deleted folder and there was nothing in there but then did a restore and there was tons of stuff in there, so I restored it all because she said that it looked like it was the stuff but I don't think it was. Anyways, the restore didn't work and there are still only two weeks of emails in her inbox. She's one of the few people here that go through all her emails and delete a lot of them and put some in folders that she really needs to keep.
I then checked around the other folders that she has and there were emails from way back, even going back years. Just to make sure, I enabled her OWA access and signed into her account on there and it had the same stuff that her outlook has so I don't think it's application related.
I'm wondering if there is anything else that I can check that could be causing this issue. I would be very appreciative for any help that can be offered.
If you have any questions for me please let me know.
Are the accounts on all computers configured as Exchange mailboxes, not POP3? Does she use any devices, such as smartphones, to read mail?
It sounds like a POp3 account deleted mail from the server - standard time to leave mail on the server is 14 days.
Yes, I have checked and all the accounts are set up with exchange accounts. Also, she does not use any devices to read her email. She just uses the computer when she's here and nothing else.
If it's not visible in OWA and there are no filters applied (use search to look for old mail), the mail was moved to a pst or deleted directly (and deleted items emptied). I would definitely disable the option to empty deleted items on exit (if enabled), just in case a rule or something is moving them to the deleted folder.
Ok, so here's another little tidbit of information. On one of the computers that she was working on, she was running on Cache Mode and one of our techs actually unchecked the box and it seems after he did that the emails went away to just two weeks worth.
I checked her computers and the outlook data files are different sizes. The one on her main computer is over 6GB but not sure why when I kick it into cache mode it doesn't fill her inbox up with tons of messages. I checked the other folders too and nothing is coming in there. I've done closing out to restarting the computer after putting it into cache mode and nothing seems to happen. 6GB seems huge for a data file for outlook and there should be stuff pouring in from there.
It seems that offline data setting is limited to 2 week. Check offline data settings & set it to maximum.
R Can only see emails no later than two weeks old! HELP! Using Outlook 5
A Record opened emails for reopening later Using Outlook 2
A Record opened emails for reopening later Outlook VBA and Custom Forms 16
A Outlook 365 Can I set up a Microsoft 365 account to capture emails sent and received from a comcast.net account? Using Outlook 7
T Emails with attachments from an alias are undeliverable to one of three aliases Using Outlook 2
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Cannot receive emails from gmail account in Outlook 365 Using Outlook 1
D Amazon and some other emails not showing in Preview Pane Using Outlook 10
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
W Outlook 2021 Hanging on "Sending Emails" Using Outlook 3
J Action based on number of emails after sort by from Using Outlook 3
D Can't read some emails - text size too small. Using Outlook 2
R How to use VB .Net to send emails? Outlook VBA and Custom Forms 0
T Outlook is categorizing emails incorrectly Using Outlook 0
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
D Delete Outlook emails from MS server Using Outlook 17
A Flagged Emails highlighted in yellow Using Outlook 3
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
J gmail and deleted emails. Using Outlook 0
U Outlook not responding when trying to print Emails Using Outlook 6
K mark emails with colour manually (like in thunderbird) Using Outlook 1
U Outlook on the iPhone cannot approve filtered Emails Using Outlook 0
B Move emails from one account to another Outlook VBA and Custom Forms 2
D Unable to view older emails in desktop app Using Outlook 0
J Outlook 365 Emails showing as links and text only Using Outlook 4
