Rule to move emails based on subject and content
Hari
Exchange Server 2010
Hello ...am looking for a rule to move inbox emails based on a subject or specific key word in the email body. For example, if an email comes with "B2B" in subject, it has to be moved to "B2B" folder. Similarly, if i have a word "Success" in the body, it should be moved to a different folder. If none matches, it needs to be remain in Inbox. Its the first time i am writing to this form, I couldnt find any similar discussions here. Can somebody help me?
S How can I create a rule to move inbound emails from any of my contacts out of Inbox? Using Outlook 1
A rule to move emails to a folder then want to delete them from that folder 2010 Using Outlook 5
L Making rule to move email to folder from one O365 domain Using Outlook 1
B Outlook 2000 Rule to Move txt msg Not Working if size >24KB Using Outlook 3
S Creating custom rule to move if "NAME" is in body but ignore the phrase "Hi NAME" in the search Using Outlook 2
N rule to move sent mail to the deleted folder in outlook Using Outlook 4
S Rule to move messages except for replies Using Outlook 5
H move to folder rule corrupts message Using Outlook 3
CWM330 This rule has a condition that the server cannot process? Using Outlook 1
A rule name into message - how? Outlook VBA and Custom Forms 5
A manual rule sends mail to wrong folder Using Outlook 5
bhamberg Finding a rouge rule... Using Outlook 6
D How to get this rule to work Using Outlook 0
R Rogue Outlook Rule ? Using Outlook 2
