Storage for Emails
Tracey Sandilands
Outlook on the web
I've just begun using Outlook.com because Outlook on my Mac keeps crashing. It doesn't have a great archiving option on Mac and I get a LOT of emails, which I just don't have time to keep deleting and managing. So for a mailbox with around 12,000 emails across 10 email addresses (some imap, some pop, some gmail and some exchange) I'm looking for an app that can handle it without my having to log in to each email address in a different program. Outlook OWA seems to be promising.
However, here's my question: I can't find out where the archives are actually stored. Are they stored in Outlook.com and if so, how much storage space do I get (I have the Microsoft Office Home subscription for $10 per month). After searching I found posts that said I only have 5 GB, and that won't last for long. I also have 1 TB in OneDrive though, but don't know how to set it up to archive older emails there instead of in the OWA. I have a 1 TB Dropbox account too, so I have storage up the yin yang but can't find how to use either of those options to store my email archive folders without a manual transfer operation.
Can anyone help?
thanks in advance.
The mailbox is 5GB, 10GB if you pay for the no mail version. The mailboxes will grow slowly as you get close to the max - however, if new mail comes in too fast, some might bounce. (The slow growth is to prevent users from uploading mail solely for the purpose of using it as an archive.) The only archive option is rules is move mail into folders - there is no offline storage.
If Windows is an option, you could archive to a pst and delete from the server, although that's not much better - it makes room on the server but the archive can only be read by outlook.
Apple mail is also an option, but it has the same limitations of outlook for windows when it comes to using the archives.
R Deleting emails from storage folder Outlook VBA and Custom Forms 1
J OUTLOOK 2016 FILE STORAGE WHERE COMMAND Using Outlook 12
M To set the storage folder for an outgoing Outlook message Outlook VBA and Custom Forms 8
Z Outlook and gmail, cloud storage and archiving Using Outlook 2
S Exchange Recovery storage Group Exchange Server Administration 8
L How I can obtain the text storage in a textbox in outlook? Outlook VBA and Custom Forms 1
KuldeepTech How Do I Extract All Emails from a PST File? Using Outlook 1
A Outlook 365 Can I set up a Microsoft 365 account to capture emails sent and received from a comcast.net account? Using Outlook 7
T Emails with attachments from an alias are undeliverable to one of three aliases Using Outlook 2
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Cannot receive emails from gmail account in Outlook 365 Using Outlook 1
D Amazon and some other emails not showing in Preview Pane Using Outlook 10
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
W Outlook 2021 Hanging on "Sending Emails" Using Outlook 3
J Action based on number of emails after sort by from Using Outlook 3
D Can't read some emails - text size too small. Using Outlook 2
R How to use VB .Net to send emails? Outlook VBA and Custom Forms 0
T Outlook is categorizing emails incorrectly Using Outlook 0
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
D Delete Outlook emails from MS server Using Outlook 17
A Flagged Emails highlighted in yellow Using Outlook 3
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
J gmail and deleted emails. Using Outlook 0
