Outlook settings will not accept a password
Maple
OS Version(s)
  1. Windows
Outlook 2021 64 bit
I am trying to add a password to my .pst file.
When I go to Settings/data settings, I am only offered to change my password. The box offers 'old password' which I ignore, and try to enter my password and repeat on the line below. The popup message says my passwords do not match.
Is this the correct place to add a password?
If you are on this dialog, its the write place. Try typing the password in notepad, copy it then paste in the password field.
Thankyou for your response Diane.
My problem is that I am trying, for the first time, to add a password (not change a password)
I need to do this as my computer has an intermittent startup problem and I need to protect my data while the machine is out for repair.
The process is the same - leave the old password field blank and add the password to the new / verify password fields.
As an FYI - password protecting a pst is not very secure.
Thanks so much Diane. However although I used the copy and paste entry, it was not accepted.
Thanks also for your reminder about the insecurity of the password.
As long as I can choose the time (!) of the trip for for the repair, I will remove my .pst file before handing the computer over.
Still the same 'passwords not matching' error? It definitely should work - I just tried it on a pst here and it worked, so Microsoft didn't break it.
Diane I am so grateful for your troubleshooting this problem
I think I may have fixed this. Early last year I was using a password with Outlook. I found the password in my Password safe, and applied it to the 'Old password' field and it accepted the new password! Hooray - Err I think :-)
One last question. Despite accepting this new password setting , my machine opened without the password. Do I have to activate it?
I've solved this.
When I added the new password ( data file/change password) I ticked the box to save the password. As was pointed out to me the computer will then save the password, thus will not prompt for it at Outlook startup!
HarvMan Outlook 365 loses "outlook.com" exchange server settings Using Outlook 1
L Recommendations for Utility to Backup Outlook 365 Account Settings Using Outlook 2
G Personal Settings within Outlook Using Outlook 2
David Langer Store my Outlook settings in the cloud - Broken Using Outlook 4
T Migrating Profile/Account Settings To New PC for Outlook 2016 Using Outlook 2
F Missing "More Settings" in Outlook 2007 Professional Using Outlook 8
E Moving autoarchive settings to new computer (Outlook 2007) Using Outlook 1
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
O Outlook 2013 not holding bottom navigation settings Using Outlook 10
I Reconfigure standard Outlook settings on all machines Using Outlook 0
M authentication settings for outlook for mac 2011 Using Outlook 1
H Hotmail set not to delete from other accounts, but did. Settings in Outlook? Using Outlook.com accounts in Outlook 0
V Changing Outlook settings Using Outlook 0
P Setting Hotmail Junk Mail Settings from Outlook Doesn't Work Using Outlook.com accounts in Outlook 1
S transfer email account settings from Outlook 2007 to 2010 Using Outlook 5
H Where does Outlook 2007 save the default reminder settings? Outlook VBA and Custom Forms 1
V Outlook 2007: How to read/write Out-of-Office settings Outlook VBA and Custom Forms 3
KuldeepTech How to Remove Multiple Duplicate Outlook PST Files from My Computer? Using Outlook 0
S Volunteer request: opening invented MSG files in Outlook for Windows Using Outlook 0
A How to Convert an Orphaned OST File Without Outlook or Exchange? Using Outlook 3
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 6
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 5
B Sync Google Calendar with Outlook Using Outlook 5
