Format Lost between Tasks and To Do
LoztInSpace
Outlook 365 64 bit
I use Outlook 365 Tasks on my Win11 desktop for all my task management. I also rely on Microsoft’s Android To Do for routinely accessing them on my phone when traveling. Unfortunately, the formatting between the two apps is not compatible so I have eliminated all graphics and keep the formatting simple.
However, there are still problems; for example, even though bullets are now supported in To Do, they don’t sync properly with Tasks
I originally defined the bullet list in To Do as follows:
  • Plan1
    • Sub A
    • Sub B
    • Sub C
    • Sub D
In Outlook Tasks, it looks like this
• Plan1
• Sub A
• Sub B
• Sub C
• Sub D
I have also tried first defining the list in Outlook Tasks, and in To Do, it looks fine, but if I make any edit, once opened again in Outlook, the list is flattened as above.
Is there a particular font or type of bullet character that would sync better?
R Lost PST files after format Using Outlook 6
fitzgerald Lost PST files after format - how to recover deleted files? Using Outlook 3
L Excel table format lost in Outlook Using Outlook 6
D outlook 2010 table format lost on send Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
S Combination Field (Date Format) Outlook VBA and Custom Forms 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
S Format Inbox Using Outlook 0
P Short Date Format when typing in a task Using Outlook 2
L Time format in Outlook calendar and emails Using Outlook 0
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
Witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
M font format discrepancies with Quick Parts Using Outlook 1
S Email Format With Embedded Images and Tables Change Using Outlook 2
G How to filter by the format of an email address Using Outlook 6
Dr. Demento Outlook output to array -> Excel & re-format Using Outlook 2
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
skylark53 Loss of default format on deleting signature Using Outlook 5
O Setting default format for composing/replying to emails Using Outlook 3
divan VbaProject: Changing email format Using Outlook 15
O VBA to change message format and add formatted signature Outlook VBA and Custom Forms 1
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
M Macro to Format certain words in email message Outlook VBA and Custom Forms 5
J Format change when dragging from email to Task Using Outlook 1
P Outlook 2013 Phone Number Format Using Outlook 0
R How to format text within appointment/meeting body? Using Outlook 6
M Email Format getting changed to Plain Text Using Outlook 1
H Disaster. Management wants to change email format. Exchange Server Administration 9
S Change answer format Using Outlook 1
R printing custom number of calendar days in weekly view format Using Outlook 1
M Save embedded image in native format Using Outlook 6
P Template format not preserved Using Outlook 3
R NUMBER Format Using Outlook 0
M Mail in HTML format can't be sent if url or number is in the body Outlook 2010 Using Outlook 2
B Changing Calendar format Using Outlook 1
M How can I send a Task Request using vCalender/vTodo format using C# Using Outlook 3
